[blockMesh] blockMesh to generate the mesh of a deep cavity
Old   July 2, 2015, 11:13
Default blockMesh to generate the mesh of a deep cavity
DongHo
eddykendo is on a distinguished road
Dear. Foamers
Hi..
I am trying to generate a mesh for a deep cavity.
However, there were some of errors in generating it as follows(blockMeshDict, error message).
I will appreciate it if someone can check a blockMeshDict file and give a good advice for me.
Thank you.
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0.0 0.0 -0.05)
(0.05 0.0 -0.05)
(0.05 -0.12 -0.05)
(0.1 -0.12 -0.05)
(0.1 0.0 -0.05)
(0.3 0.0 -0.05)
(0.0 0.1 -0.05)
(0.05 0.1 -0.05)
(0.1 0.1 -0.05)
(0.3 0.1 -0.05)
(0.0 0.0 0.05)
(0.05 0.0 0.05)
(0.05 -0.12 0.05)
(0.1 -0.12 0.05)
(0.1 0.0 0.05)
(0.3 0.0 0.05)
(0.0 0.1 0.05)
(0.05 0.1 0.05)
(0.1 0.1 0.05)
(0.3 0.1 0.05)
blocks
hex (0 1 7 6 10 11 17 16) (48 16 1) simpleGrading (1 1 1)
// hex (4 1 2 3 14 11 12 13) (96 32 1) simpleGrading (1 1 1)
hex (2 3 4 1 12 13 14 11) (48 16 1) simpleGrading (1 1 1)
hex (1 4 8 7 11 14 18 17) (48 16 1) simpleGrading (1 1 1)
hex (4 5 9 8 14 15 19 18) (48 16 1) simpleGrading (1 1 1)
edges
boundary
inlet
type patch;
faces
(0 6 16 10)
outlet
type patch;
faces
(5 9 19 15)
/* cavity
type wall;
faces
(2 3 13 12) //(0 10 11 1)
top
type symmetryPlane;
faces
(6 16 17 7)
(7 17 18 8)
(8 18 19 9)
bottom
type wall;
faces
(0 1 11 10)
(1 2 12 11)
(2 3 13 12)
(3 4 14 13)
(4 5 15 14)
mergePatchPairs
Build : 2.3.0-f5222ca19ce6
Exec : blockMesh
Date : Jul 02 2015
Time : 23:06:37
Host : "user-All-Series"
PID : 2982
Case : /home/user/OpenFOAM/user-2.3.0/run/forwardStep
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Creating block mesh from
"/home/user/OpenFOAM/user-2.3.0/run/forwardStep/constant/polyMesh/blockMeshDict"
Creating curved edges
Creating topology blocks
Creating topology patches
Creating block mesh topology
--> FOAM Warning :
From function polyMesh:olyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 903
Found 8 undefined faces in mesh; adding to default patch.
Check topology
Basic statistics
Number of internal faces : 3
Number of boundary faces : 18
Number of defined boundary faces : 18
Number of undefined boundary faces : 0
Checking patch -> block consistency
Creating block offsets
Creating merge list .
Creating polyMesh from blockMesh
Creating patches
Creating cells
Creating points with scale 1
Block 0 cell size :
i : 0.00104167 .. 0.00104167
j : 0.00625 .. 0.00625
k : 0.1 .. 0.1
Block 1 cell size :
j : 0.0075 .. 0.0075
k : 0.1 .. 0.1
Block 2 cell size :
k : 0.1 .. 0.1
Block 3 cell size :
i : 0.00416667 .. 0.00416667
k : 0.1 .. 0.1
Writing polyMesh
Mesh Information
boundingBox: (0 -0.12 -0.05) (0.3 0.1 0.05)
nPoints: 6498
nCells: 3072
nFaces: 12464
nInternalFaces: 5968
Patches
patch 0 (start: 5968 size: 16) name: inlet
patch 1 (start: 5984 size: 16) name: outlet
patch 2 (start: 6000 size: 144) name: top
patch 3 (start: 6144 size: 176) name: bottom
patch 4 (start: 6320 size: 6144) name: defaultFaces
End
eddykendo is offline   Reply With Quote
Old   July 3, 2015, 10:42
Alexander Bartel
alexB is on a distinguished road
Hi Dong Ho,
could you draw a sketch of your geometry... that would help me to visualize your mesh.
regards
Alex
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
alexB is offline   Reply With Quote
Old   July 4, 2015, 23:02
DongHo
Hi.. Alex
Thank you for your response.
I managed to generate a mesh for a supersonic cavity.
However, that is not good enough because I will need grid grading in multi-direction. I know that OpenFOAM versions before v2.40 do not provide the multi-grading of the grid. I guess I might be able to generate the mesh I will eventually need if I divide a domain into many blocks. But, dividing it more blocks will be quite tedious works. So, I'd like to know if there is a good way to generate the mesh like that. I have attached the mesh I generated. The left side is an inlet and the right side is outlet. The top and bottom sides are walls. As you know, the mesh will need to be expanded from both walls on the top and bottom, also from the sides of the cavity.
So, can OpenFOAM v 2.40 be installed into Ubuntu 12.04 LTS? It is said on the web that OpenFOAM v2.40 can be installed into Ubuntu 14.04 LTS though.. Is there any way to install OpenFOAM v2.40 into Ubuntu 12.04 LTS? since v2.40 can provide multi-grading mesh.
I will appreciate it if you can let me know these kinds of things.
FoamFile
version 2.0;
format ascii;
class dictionary;
convertToMeters 0.1;
vertices
(0 0 0)
(1 0 0)
(1 1 0)
(0 1 0)
(0 0 0.1)
(1 0 0.1)
(1 1 0.1)
(0 1 0.1)
blocks
hex (0 1 2 3 4 5 6 7) (20 20 1) simpleGrading (1 1 1)
edges
boundary
movingWall
type wall;
faces
(3 7 6 2)
fixedWalls
type wall;
faces
(0 4 7 3)
(2 6 5 1)
(1 5 4 0)
frontAndBack
type empty;
faces
(0 3 2 1)
(4 5 6 7)
mergePatchPairs
Old   July 4, 2015, 23:06
Default blockMeshDict file
DongHo
Sorry I have attached a wrong file.
This is my blockMeshDict file for a supersonic cavity.
Thanks
FoamFile
version 2.0;
format ascii;
class dictionary;
convertToMeters 1;
vertices
(0.0 0.0 -0.06)
(0.05 0.0 -0.06)
(-0.05 0.12 -0.06)
(0.0 0.12 -0.06)
(0.05 0.12 -0.06)
(0.25 0.12 -0.06)
(-0.05 0.22 -0.06)
(0.0 0.22 -0.06)
(0.05 0.22 -0.06)
(0.25 0.22 -0.06)
(0.0 0.0 0.06)
(0.05 0.0 0.06)
(-0.05 0.12 0.06)
(0.0 0.12 0.06)
(0.05 0.12 0.06)
(0.25 0.12 0.06)
(-0.05 0.22 0.06)
(0.0 0.22 0.06)
(0.05 0.22 0.06)
(0.25 0.22 0.06)
blocks
hex (0 1 4 3 10 11 14 13) (72 96 32) simpleGrading (4 0.25 1)
/* simpleGrading
(0.2 0.3 4)
(0.6 0.4 1)
(0.2 0.3 0.25)
(0.2 0.3 4)
(0.6 0.4 1)
(0.2 0.3 0.25)
1
hex (2 3 7 6 12 13 17 16) (72 64 32) simpleGrading (0.25 4 1)
/* simpleGrading
(0.4 0.3 4)
(0.6 0.7 0.25)
(0.4 0.3 4)
(0.6 0.7 0.25)
1
hex (3 4 8 7 13 14 18 17) (72 64 32) simpleGrading (4 4 1)
/* simpleGrading
(0.2 0.3 4)
(0.6 0.4 1)
(0.2 0.3 0.25)
(0.4 0.3 4)
(0.6 0.7 0.25)
1
hex (4 5 9 8 14 15 19 18) (96 64 32) simpleGrading (8 4 1)
/* simpleGrading
(0.4 0.3 4)
(0.6 0.7 0.25)
(0.4 0.3 4)
(0.6 0.7 0.25)
1
edges
boundary
inlet
type patch;
faces
(2 6 16 12)
outlet
type patch;
faces
(5 9 19 15)
/* cavity
type wall;
faces
top
type wall; //symmetryPlane;
faces
(6 16 17 7)
(7 17 18 8)
(8 18 19 9)
bottom
type wall;
faces
(2 3 13 12)
(3 0 10 13)
(0 1 11 10)
(1 4 14 11)
(4 5 15 14)
back
type empty;
faces
(0 3 4 1)
(2 6 7 3)
(3 7 8 4)
(4 8 9 5)
front
type empty;
faces
(10 13 14 11)
(12 16 17 13)
(13 17 18 14)
(14 18 19 15)
mergePatchPairs
Old   July 5, 2015, 17:54
Alexander Bartel
sorry, I didn't realized your new questions the post before...
I don't know much about multigrading and installation issues...
Perhaps you post your question about the installation of OF2.4 in another subforum.
regards
Alex
[ANSYS Meshing] How to generate this mesh Yassin ANSYS Meshing & Geometry 0 February 28, 2017 01:15
[Gmsh] gMsh instead of blockMesh for base mesh, then snappyHexMesh sazabi2001 OpenFOAM Meshing & Mesh Conversion 0 February 23, 2017 13:00
[snappyHexMesh] Snappyhex mesh: poor inlet mesh Swagga5aur OpenFOAM Meshing & Mesh Conversion 1 December 3, 2016 17:59
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
[Other] Problem when trying to generate a new mesh gaottino OpenFOAM Meshing & Mesh Conversion 0 June 30, 2006 08:51
