[Other] cellLevel field not readable by topoSet |
P.A.
Rep Power: 17 ![]() |
Dear All,
i am facing a problem with topoSet when i try to use the field cellLevel to select cells. topoSet cannot find the cellLevel file. I need this because I want to do mesh refinement in dependence of the previous refinement level. This worked in OpenFOAM 2.2.x. Currently i am using build 2.3.x-2d875bf8e478. Here is my topoSetDict: Code:
actions ( { name FS; type cellSet; action new; source boxToCell; sourceInfo { box (-1000 -1000 -1.7) (1000 1000 1.7); } } // values of field within certain range { name FS; type cellSet; action subset; source fieldToCell; sourceInfo { fieldName cellLevel; min 4; max 4; } } ); Code:
... Create polyMesh for time = 66 Reading topoSetDict Time = 66 mesh not changed. Created cellSet FS Applying source boxToCell Adding cells with center within boxes 1((-1000 -1000 -1.7) (1000 1000 1.7)) cellSet FS now size 406636 Read set cellSet FS with size 406636 Applying source fieldToCell --> FOAM Warning : From function fieldToCell::applyToSet(const topoSetSource::setAction, topoSet& set) in file sets/cellSources/fieldToCell/fieldToCell.C at line 203 Cannot read field cellLevel from time 66 cellSet FS now size 0 End I thought this issue could depend on the debug setting in snappyHexMeshDict. Setting this to 2 is meant to give: Code:
2 : write volScalarField with cellLevel for postprocessing So, how can topoSet get access to cellLevel information again? Thank you! |
simpleDyMFoam on v1806 | gamemakerh | OpenFOAM Programming & Development | 0 | November 8, 2018 08:15 |
potential flows, helmholtz decomposition and other stuffs | pigna | Main CFD Forum | 1 | October 26, 2017 08:34 |
Access to field which is evaluated at the moment | Tobi | OpenFOAM Programming & Development | 6 | April 19, 2017 13:09 |
[General] How to create an additional vector with {Field 4, Field 5, Field 6} | Bombacar | ParaView | 1 | August 15, 2015 18:05 |
Demagnetization field | jan0385 | ANSYS | 0 | April 12, 2012 09:09 |
