[snappyHexMesh] Modifications with SnappyHexMesh: create a beach in order to prevent reflected waves |
June 23, 2015, 08:28 |
Maxime Le Bihan
Rep Power: 11 |
Hello everyone,
First of all thanks for the huge amount of information available on this forum, it helped me to be introduced to this amazing software. I want to create a beach in order to prevent reflected waves in my numerical tank. In order to have the specific shape, I use the snappyHexMesh tool to import my .stl file. My tank is devided in three blocks, water, surface layer and air. My beach get across these three blocks in order to have a good accuracy of the wave breaking. When I want to check the mesh without the beach, every thing is good but when I run snappyHexMesh and then paraFoam, I can see that most part of the previous mesh disappeared and the mesh is focused close to the beach. I checked several time the .stl and snappyHexMesh file and everything seems to be good. My supervisor told me that he faced this kind of problem but he didnt managed to find a good reason why this problem occured. If any of you have ever faced this problem, let me know Cheers, Max |
July 1, 2015, 04:09 |
Eloïse
Rep Power: 14 |
Hi Max,
Welcome to the forum Could you post one or two images of your mesh to illustrate your issue? Regards, Eloïse |
July 8, 2015, 08:27 |
Maxime Le Bihan
Rep Power: 11 |
Hi Eloise,
Sorry for my late answer, I fixed the problem by adding more cells to my .stl shape. For those who want to create a simple shape and then import the .stl file to openFoam, the free software OpenScad is very good, easy to handle and well documented with OpenscadWiki. Cheers, Max |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[blockMesh] Include list of points | Hikachu | OpenFOAM Meshing & Mesh Conversion | 0 | June 20, 2011 10:03 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 08:06 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 02:07 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
