[Other] Wedge patch '*' is not planar |
June 18, 2015, 12:41 |
#1 | |
Chris
Rep Power: 11 |
This is about a 2D axissymetric case. I was using a Matlab script to find the edges of the blocks I want to build. (you find the Matlab script in the attachment) checkMesh gives the output: Quote:
blockMeshDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (6.497773e-02 -1.701502e-03 0) (6.497773e-02 1.701502e-03 0) (6.517266e-02 1.706606e-03 0) (6.517266e-02 -1.706606e-03 0) (6.497773e-02 -1.701502e-03 2.000000e-03) (6.497773e-02 1.701502e-03 2.000000e-03) (6.517266e-02 1.706606e-03 2.000000e-03) (6.517266e-02 -1.706606e-03 2.000000e-03) (6.497773e-02 -1.701502e-03 2.200000e-03) (6.497773e-02 1.701502e-03 2.200000e-03) (6.517266e-02 1.706606e-03 2.200000e-03) (6.517266e-02 -1.706606e-03 2.200000e-03) (6.537259e-02 -1.711842e-03 2.000000e-03) (6.537259e-02 1.711842e-03 2.000000e-03) (7.180039e-02 1.880159e-03 2.000000e-03) (7.180039e-02 -1.880159e-03 2.000000e-03) (6.537259e-02 -1.711842e-03 2.200000e-03) (6.537259e-02 1.711842e-03 2.200000e-03) (7.180039e-02 1.880159e-03 2.200000e-03) (7.180039e-02 -1.880159e-03 2.200000e-03) (6.497773e-02 -1.701502e-03 3.220000e-02) (6.497773e-02 1.701502e-03 3.220000e-02) (7.180039e-02 1.880159e-03 3.220000e-02) (7.180039e-02 -1.880159e-03 3.220000e-02) ); blocks ( //Block 0 hex (0 3 2 1 4 7 6 5) (1 1 1) simpleGrading ( 1 1 1 ) //Block 1 hex (4 7 6 5 8 11 10 9) (1 1 1) simpleGrading ( 1 1 1 ) //Block 2 hex (7 12 13 6 11 16 17 10) (1 1 1) simpleGrading ( 1 1 1 ) //Block 3 hex (12 15 14 13 16 19 18 17) (1 1 1) simpleGrading ( 1 1 1 ) //Block 4 hex (8 19 18 9 20 23 22 21) (1 1 1) simpleGrading ( 1 1 1 ) ); edges(); boundary ( inlet { type patch; faces ( (0 1 2 3) // von innen gesehen gegen den Uhrzeigersinn Aufgezaehlt ); } outlet { type patch; faces ( (20 23 22 21) ); } shaftInHole { type wall; faces ( (0 1 5 4) ); } shaftInFreestream { type wall; faces ( (4 5 9 8) (8 9 21 20) ); } wallInHole { type wall; faces ( (3 7 6 2) ); } wallInFreestream { type wall; faces ( (14 15 19 18) (18 19 23 22) ); } step { type wall; faces ( (6 7 12 13) (14 13 12 15) ); } front { type wedge; faces ( (1 2 6 5) (5 6 10 9) (6 13 17 10) (13 14 18 17) (9 18 22 21) ); } back { type wedge; faces ( (0 4 7 3) (4 8 11 7) (7 11 16 12) (12 16 19 15) (8 20 23 19) ); } ); mergePatchPairs(); // ************************************************************************* // Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.4.0-f0842aea0e77 Exec : blockMesh Date : Jun 18 2015 Time : 18:36:28 Host : "ChrisHP" PID : 11568 Case : /home/chris/OpenFOAM/nowak/Netzerzeugung/NeuesMesh nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "/home/chris/OpenFOAM/nowak/Netzerzeugung/NeuesMesh/constant/polyMesh/blockMeshDict" No non-linear edges defined Creating topology blocks Creating topology patches Creating block mesh topology --> FOAM Warning : From function polyMesh::polyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 903 Found 4 undefined faces in mesh; adding to default patch. --> FOAM Warning : From function wedgePolyPatch::calcGeometry(PstreamBuffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72 Wedge patch 'front' is not planar. At local face at (0.0650752 0.00170405 0.001) the normal (0.0261748 -0.999657 1.32563e-19) differs from the average normal (0.0261767 -0.999657 3.31431e-20) by 3.60957e-12 Either correct the patch or split it into planar parts --> FOAM Warning : From function wedgePolyPatch::calcGeometry(PstreamBuffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72 Wedge patch 'front' is not planar. At local face at (0.0650752 0.00170405 0.0021) the normal (0.0261748 -0.999657 1.32563e-18) differs from the average normal (0.0261767 -0.999657 3.31431e-20) by 3.60957e-12 Either correct the patch or split it into planar parts ... (Removed a few similiar Errormessages) --> FOAM Warning : From function wedgePolyPatch::calcGeometry(PstreamBuffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72 Wedge patch 'back' is not planar. At local face at (0.0685865 -0.001796 0.0021) the normal (0.0261768 0.999657 0) differs from the average normal (0.0261767 0.999657 -3.31431e-20) by 1.61774e-14 Either correct the patch or split it into planar parts --> FOAM Warning : From function wedgePolyPatch::calcGeometry(PstreamBuffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72 Wedge patch 'back' is not planar. At local face at (0.0683891 -0.00179083 0.0172) the normal (0.0261769 0.999657 0) differs from the average normal (0.0261767 0.999657 -3.31431e-20) by 2.83042e-14 Either correct the patch or split it into planar parts Check topology Basic statistics Number of internal faces : 3 Number of boundary faces : 24 Number of defined boundary faces : 24 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating polyMesh from blockMesh Creating patches Creating cells Creating points with scale 1 Block 0 cell size : i : 0.000194997 .. 0.000194997 j : 0.003403 .. 0.003403 k : 0.002 .. 0.002 Block 1 cell size : i : 0.000194997 .. 0.000194997 j : 0.003403 .. 0.003403 k : 0.0002 .. 0.0002 Block 2 cell size : i : 0.000199999 .. 0.000199999 j : 0.00341321 .. 0.00341321 k : 0.0002 .. 0.0002 Block 3 cell size : i : 0.00643 .. 0.00643 j : 0.00342368 .. 0.00342368 k : 0.0002 .. 0.0002 Block 4 cell size : i : 0.006825 .. 0.006825 j : 0.003403 .. 0.003403 k : 0.03 .. 0.03 --> FOAM Warning : From function wedgePolyPatch::calcGeometry(PstreamBuffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72 Wedge patch 'front' is not planar. At local face at (0.0650752 0.00170405 0.001) the normal (-0.0261748 0.999657 1.32563e-19) differs from the average normal (-0.0261767 0.999657 3.31431e-20) by 3.60957e-12 Either correct the patch or split it into planar parts ... (Removed a few similiar Errormessages) --> FOAM Warning : From function wedgePolyPatch::calcGeometry(PstreamBuffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72 Wedge patch 'back' is not planar. At local face at (0.0683891 -0.00179083 0.0172) the normal (-0.0261769 -0.999657 0) differs from the average normal (-0.0261767 -0.999657 -3.31431e-20) by 2.83042e-14 Either correct the patch or split it into planar parts There are no merge patch pairs edges Writing polyMesh ---------------- Mesh Information ---------------- boundingBox: (0.0649777 -0.00188016 0) (0.0718004 0.00188016 0.0322) nPoints: 28 nCells: 5 nFaces: 27 nInternalFaces: 3 ---------------- Patches ---------------- patch 0 (start: 3 size: 1) name: inlet patch 1 (start: 4 size: 1) name: outlet patch 2 (start: 5 size: 1) name: shaftInHole patch 3 (start: 6 size: 2) name: shaftInFreestream patch 4 (start: 8 size: 1) name: wallInHole patch 5 (start: 9 size: 2) name: wallInFreestream patch 6 (start: 11 size: 2) name: step patch 7 (start: 13 size: 5) name: front patch 8 (start: 18 size: 5) name: back patch 9 (start: 23 size: 4) name: defaultFaces End Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.4.0-f0842aea0e77 Exec : checkMesh Date : Jun 18 2015 Time : 18:36:40 Host : "ChrisHP" PID : 11574 Case : /home/chris/OpenFOAM/nowak/Netzerzeugung/NeuesMesh nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 --> FOAM Warning : From function wedgePolyPatch::calcGeometry(PstreamBuffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72 Wedge patch 'front' is not planar. At local face at (0.0650752 0.00170405 0.001) the normal (-0.0261748 0.999657 1.32563e-19) differs from the average normal (-0.0261767 0.999657 3.31431e-20) by 3.60957e-12 Either correct the patch or split it into planar parts --> FOAM Warning : From function wedgePolyPatch::calcGeometry(PstreamBuffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72 Wedge patch 'front' is not planar. At local face at (0.0650752 0.00170405 0.0021) the normal (-0.0261748 0.999657 1.32563e-18) differs from the average normal (-0.0261767 0.999657 3.31431e-20) by 3.60957e-12 Either correct the patch or split it into planar parts --> FOAM Warning : From function wedgePolyPatch::calcGeometry(PstreamBuffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72 Wedge patch 'front' is not planar. At local face at (0.0652726 0.00170922 0.0021) the normal (-0.0261802 0.999657 -1.29248e-18) differs from the average normal (-0.0261767 0.999657 3.31431e-20) by 1.22804e-11 Either correct the patch or split it into planar parts ... (Removed a few similiar Errormessages) --> FOAM Warning : From function wedgePolyPatch::calcGeometry(PstreamBuffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72 Wedge patch 'back' is not planar. At local face at (0.0683891 -0.00179083 0.0172) the normal (-0.0261769 -0.999657 0) differs from the average normal (-0.0261767 -0.999657 -3.31431e-20) by 2.83042e-14 Either correct the patch or split it into planar parts Time = 0 Mesh stats points: 28 internal points: 0 faces: 27 internal faces: 3 cells: 5 faces per cell: 6 boundary patches: 10 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 5 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. ***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 2 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" <<Writing region 0 with 4 cells to cellSet region0 <<Writing region 1 with 1 cells to cellSet region1 Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 1 4 ok (non-closed singly connected) outlet 1 4 ok (non-closed singly connected) shaftInHole 1 4 ok (non-closed singly connected) shaftInFreestream 2 8 ok (non-closed singly connected) wallInHole 1 4 ok (non-closed singly connected) wallInFreestream 2 8 ok (non-closed singly connected) step 2 6 ok (non-closed singly connected) front 5 14 ok (non-closed singly connected) back 5 14 ok (non-closed singly connected) defaultFaces 4 12 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0.0649777 -0.00188016 0) (0.0718004 0.00188016 0.0322) Mesh (non-empty, non-wedge) directions (1 0 1) Mesh (non-empty) directions (1 1 0) Wedge front with angle 1.49998 degrees Wedge back with angle 1.49998 degrees All edges aligned with or perpendicular to non-empty directions. Boundary openness (2.05835e-17 0 0) OK. Max cell openness = 8.2747e-17 OK. Max aspect ratio = 30.7004 OK. Minimum face area = 3.89994e-08. Maximum face area = 0.00020475. Face area magnitudes OK. Min volume = 1.32868e-10. Max volume = 7.33094e-07. Total volume = 7.3931e-07. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.0653982 OK. Coupled point location match (average 0) OK. Mesh OK. Time = 1 Mesh stats points: 28 internal points: 0 faces: 27 internal faces: 3 cells: 5 faces per cell: 6 boundary patches: 10 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 5 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. ***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 2 The mesh has multiple regions which are not connected by any face. <<Writing region information to "1/cellToRegion" <<Writing region 0 with 1 cells to cellSet region0 <<Writing region 1 with 4 cells to cellSet region1 Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 1 4 ok (non-closed singly connected) outlet 1 4 ok (non-closed singly connected) shaftInHole 1 4 ok (non-closed singly connected) shaftInFreestream 2 8 ok (non-closed singly connected) wallInHole 1 4 ok (non-closed singly connected) wallInFreestream 2 8 ok (non-closed singly connected) step 2 6 ok (non-closed singly connected) front 5 14 ok (non-closed singly connected) back 5 14 ok (non-closed singly connected) defaultFaces 4 12 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0.0649777 -0.00188016 0) (0.0718004 0.00188016 0.0322) Mesh (non-empty, non-wedge) directions (1 0 1) Mesh (non-empty) directions (1 1 0) Wedge front with angle 1.49998 degrees Wedge back with angle 1.49998 degrees All edges aligned with or perpendicular to non-empty directions. Boundary openness (2.05835e-17 0 0) OK. Max cell openness = 8.2747e-17 OK. Max aspect ratio = 30.7004 OK. Minimum face area = 3.89994e-08. Maximum face area = 0.00020475. Face area magnitudes OK. Min volume = 1.32868e-10. Max volume = 7.33094e-07. Total volume = 7.3931e-07. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.0653982 OK. Coupled point location match (average 0) OK. Mesh OK. End |
June 20, 2015, 03:35 |
Chris
Rep Power: 11 |
Ok, Problem was solved by setting the angle to 0 and all y values to -1 or +1. I also changed the type of the front and back surfaces to patch. So I got a 2D plane mesh. In a new case dir I executed extrudeMesh with the wedge options using the front and back patches as input. It worked =)
October 6, 2015, 10:26 |
makeAxialMesh
Antony Premkumar
Rep Power: 11 |
I couldn't really understood how you solved it.
Could you please explain me what angle did you change to 0. I am also facing the same problem. Plus my check mesh is showing mesh not OK with seven errors |
November 24, 2015, 18:32 |
Alex
Rep Power: 15 |
Antony: I had some similar issues recently with axisymmetric meshes. I had success switching the writeFormat in controlDict from ascii to binary.
I guess there is some rounding introduced when you convert back and forth from human readable format. It would be nice if there was some place to adjust the precision requirement for wedge planar-ness. |
May 21, 2016, 07:50 |
Ignore and proceed to computation
Smrutimaya Pattanaik
Those error messages are not very serious, ignore and proceed to computation.
February 1, 2018, 15:51 |
Foad
Rep Power: 9 |
I had a same issue with an axisymmetric geometry/mesh I created with Gmsh. I reran the gmshToFoam and edited the constant/polyMesh/boundary file manually, changing the wedges type and physicalType to wedge and the noslip walls to wall. it solved the problem and ran smoothly.
January 12, 2021, 05:55 |
Naveen kumar
I want to do 2d axisymmertic meshing in OpenFoam. But it is showing this error "Either correct the patch or split it into planar parts". Please have a look on it.
September 18, 2024, 05:52 |
You can try increasing the writePrecision in controlDict (writePrecision 10; ). It worked for me.
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
steadyUniversalMRFFoam Tutorial fails in MixingPlane | HenrikJohansson | OpenFOAM Bugs | 0 | February 14, 2019 04:48 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 13:48 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
