May 18, 2015, 10:24 |
import mesh from salome to openfoam
domenico
Rep Power: 11 |
Hi I'm very new in openFoam, and I'm sorry for my basic english! However I'm building the geometry and the mesh for a static mixer with salome but when I import yhe mesh openform cannot generate the mesh... This is the error
Create time Processing tag:164 Starting reading units at line 3. l:1 units:" SI: Meter (newton)" unitType:2 Unit factors: Length scale : 1 Force scale : 1 Temperature scale : 1 Temperature offset : 273.15 Processing tag:2420 Skipping tag 2420 on line 9 Skipping section at line 9. Processing tag:2411 Starting reading points at line 20. Read 2300 points. Processing tag:2412 Starting reading cells at line 4623. First occurrence of element type 11 for cell 1 at line 4624 First occurrence of element type 41 for cell 425 at line 5896 Read 0 cells and 4596 boundary faces. Processing tag:2467 Starting reading patches at line 15090. For group 1 named wall trying to read 4596 patch face indices. Sorting boundary faces according to group (patch) 0: wall is #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 at ??:? #4 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #5 at ??:? Errore di segmentazione (core dump creato) Please somebody can help me? |
April 20, 2016, 08:23 |
dklogo
Rep Power: 11 |
Hi domenico,
i am facing the same problem with you . Did you find a solution ? If yes, can you give some help with this ? |
April 20, 2016, 23:58 |
Hi
This might help you. Just give it try. http://www.cfd-online.com/Forums/blo...onversion.html https://github.com/nicolasedh/salome...eToOpenFOAM.py Regards, kkk |
[Salome] mesh conversion Salome --> OpenFoam | vaina74 | OpenFOAM Meshing & Mesh Conversion | 42 | March 4, 2022 20:41 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[ANSYS Meshing] Import Mesh from CFX-Solve to OpenFOAM | A.Stamatopol | ANSYS Meshing & Geometry | 1 | July 25, 2013 11:08 |
Converting Salome hybrid mesh to OpenFOAM | Arnoldinho | OpenFOAM | 4 | March 28, 2012 10:24 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
