[Other] topoSet Wrong number of faces.
Old   May 14, 2015, 10:56
Question topoSet Wrong number of faces.
zech
a19910112a is on a distinguished road
Hi Foamers. I came across the same problem as describeded in http://www.cfd-online.com/Forums/openfoam-meshing-blockmesh/128416-problems-holes-gaps-baffle-internal-wall-zero-thickness.html.
I did the same thing as described in the referred post.
To solve this problem, I located the problem at topoSet. It recognise a wrong number of faces.
My blockMeshDict is as :
convertToMeters 1;
vertices
        (0    0    0    )    //    0
        (2.4424    0    0.1065158)    //    1
        (2.4424    0    -0.1065158)    //    2
        (0    1    0    )    //    3
        (2.4424    1    0.1065158)    //    4
        (2.4424    1    -0.1065158)    //    5
        (4.25    0    0.1853472)    //    6
        (4.25    0    -0.1853472)    //    7
        (4.25    1    0.1853472)    //    8
        (4.25    1    -0.1853472)    //    9
//local axes (z x y)
blocks
        hex    (1      2    0    0    4    5    3    3    )    innerCore        (1    26    10)    simpleGrading    (1    1    1)
        hex    (6    7    2    1    8    9    5    4    )    radialReflector        (1    18    10)    simpleGrading    (1    1    1)
edges
This generate a mesh of a wedge which is shown in the first attached pic. There are 10 meshes in the y direction.
I want to add a baffle wall in the middle of the wedge, which is shown in the second attachment.
The toposet file :
actions
        name    baffle;
        type    faceSet;
        action  new;
        source  boxToFace;
        sourceInfo
    box (2.4424    0 -0.107) (2.4424 1 0.107); //24
        name    baffle;
        type    faceZoneSet;
        action  new;
        sourceInfo
        source  setToFaceZone;
            faceSet baffle;
the log it generates:
Create time
Create polyMesh fluid for time = 0
Reading topoSetDict
Time = 0
    mesh not changed.
Created faceSet baffle
    Applying source boxToFace
    Adding faces with centre within boxes 1((2.4424 0 -0.107) (2.4424 1 0.107))
    faceSet baffle now size 9
Created faceZoneSet baffle
    Applying source setToFaceZone
    Adding all faces from faceSet baffle ...
    faceZoneSet baffle now size 9
End
As can be seen, topoSet recognises only 9 faces where 10 are expected, which gives the baffle shown in the second pic.
Can anyone tell me where the problem could be and how can I solve it ?
By the way, I also tried to use points 42, 15, 51, as the two points after the box item in topoSet. In those cases only 0 face could be recognised. This seems to be due to some similar or related reasons.
Thanks
File Type: jpg Screenshot from 2015-05-14 14:29:33.jpg (17.1 KB, 24 views)
File Type: jpg Screenshot from 2015-05-14 14:48:27.jpg (15.7 KB, 22 views)
a19910112a is offline   Reply With Quote
Old   June 9, 2015, 06:41
Howar
Howard is on a distinguished road
convertToMeters 1;
vertices
        (0    0    0    )    //    0
        (0    1    0    )    //    3
blocks
edges
The toposet file :
actions
        name    baffle;
        type    faceSet;
        action  new;
        source  boxToFace;
        sourceInfo
        name    baffle;
        type    faceZoneSet;
        action  new;
        sourceInfo
            faceSet baffle;
Create time
Reading topoSetDict
Time = 0
    mesh not changed.
End
Thanks
Hi friend, I also have some problem that when I use the toposet it shows cellzoneset size 0. but I think my boxes is defined right. Have you solve your problem?
Howard is offline   Reply With Quote
creatbaffles, mesh, toposet
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 09:26
parallel run OpenFoam Srinath Reddy OpenFOAM Running, Solving & CFD 13 February 27, 2019 10:15
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 09:14
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 11:27
