[mesh manipulation] Iterate refineMesh
Old   May 13, 2015, 06:07
Default Iterate refineMesh
sgr
Simon Grützner
sgr is on a distinguished road
Dear FOAMers,
this is my first thread and I am quite new to this library. First of all, i'd like to thank you all for a great forum. It helped me so much this far and will probably continue to do so for a long time.
I encountered the following problem. I have a fairly simple block like geometry (cf. the attached images) and want to use refineMesh in two sequential steps.
The first step intends to refine half the domain and the second just a part of that just refined region.
I used the following commands in an Allrun bash script to execute the refineMesh command sequentially:
runApplication blockMesh
runApplication topoSet -dict sytstem/refine.topoSetDict.1
runApplicattion refineMesh -overwrite -dict system/refineMeshDict.1
rm log.topoSet
runApplication topoSet -dict sytstem/refine.topoSetDict.2
runApplication refineMesh -overwrite -dict system/refineMeshDict.2
rm log.topoSet
refine.topoSetDict.{1,2} define the cellSets refineCells1 and refineCells2, respectively. The refineMeshDict then looks like this:
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      refineMeshDict;
// Cells to refine; name of cell set
set refineCells1;
// Type of coordinate system:
// - global : coordinate system same for every cell. Usually aligned with
//   x,y,z axis. Specify in globalCoeffs section below.
// - patchLocal : coordinate system different for every cell. Specify in
//   patchLocalCoeffs section below.
//coordinateSystem global;
// .. and its coefficients. x,y in this case. (normal direction is calculated
// as tan1^tan2)
globalCoeffs
    tan1 (0 0 1);
    tan2 (1 0 0);
patchLocalCoeffs
    patch patchName; //Normal direction is facenormal of zero'th face of patch
    tan1 (0 0 1);
    tan2 (1 0 0);
// List of directions to refine
directions
    tan1
    tan2
    //    normal
// Whether to use hex topology. This will
// - if patchLocal: all cells on selected patch should be hex
// - split all hexes in 2x2x2 through the middle of edges.
useHexTopology  true;
// Cut purely geometric (will cut hexes through vertices) or take topology
// into account. Incompatible with useHexTopology
geometricCut    false;
// Write meshes from intermediate steps
writeMesh        false;
where the sets at the top are named refineCells1 and refineCells2, respectively.
When I run the script, only the first cellSet is refined and the second one not. I also looked at both pages of the thread
http://www.cfd-online.com/Forums/ope...efinemesh.html
but did not succeed in applying it to my case. Can anyone explain to me, what i am doing wrong here?
Best regards,
Simon
Last edited by sgr; May 13, 2015 at 06:47. Reason: uploaded an older version of my refineMeshDict
sgr is offline   Reply With Quote
Old   May 13, 2015, 06:49
sgr
Simon Grützner
Hi FOAMers,
the problem was, that i did not delete the log.refineMesh file. Adding
rm log.refineMesh
to the Allrun script solves the problem and the Case now runs like a charm. :-)
mesh, refinemesh, toposet
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing Regis_ OpenFOAM Meshing & Mesh Conversion 2 June 4, 2015 14:44
[mesh manipulation] checkMesh Erros after refineMesh mgdenno OpenFOAM Meshing & Mesh Conversion 10 October 14, 2014 06:16
[mesh manipulation] Cannot get refineMesh to run in parallel smschnob OpenFOAM Meshing & Mesh Conversion 2 June 3, 2014 12:20
[mesh manipulation] refineMesh inverses face normals? RoE OpenFOAM Meshing & Mesh Conversion 3 August 3, 2012 12:41
checkMesh Errors after refineMesh mgdenno OpenFOAM 0 July 30, 2012 22:39
