[snappyHexMesh] Why does the motorBike tutorial run in parallel?
Old   May 8, 2015, 12:35
Default Why does the motorBike tutorial run in parallel?
BastiL
bastil is on a distinguished road
I know sounds silly ....
Running the motorbike-tutorial in parallel works fine. After snappyHexMesh, all field-files (u, p, ...) need to be adapted to get the "procBoundary*"-Patches included. At least is this the case for all simulations I am trying to run. My workaround is to do "reconstructParMesh" and "decomposePar" after running sHM in parallel to get simpleFoam running in parallel afterwards. This is annoying.
However, the motorbike-tutorial runs without this, it only copys field-files from "0.org" to processor*/0. Theses files do not contain "procBoundary*"-Patches, but simpleFoam runs. Why?
bastil is offline   Reply With Quote
[Salome] Salome import "Cannot find file "points" in directory..." mismichael OpenFOAM Meshing & Mesh Conversion 6 June 24, 2024 04:17
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 12:58
Tutorial 2 - Parallel run nicholas_yue SU2 2 March 25, 2014 13:53
Cannot run the code in parallel. Help please (urgent). crst15 OpenFOAM 11 February 17, 2014 02:02
First Parallel Run - need some help Gian Maria OpenFOAM 3 June 17, 2011 13:08
