[Other] Mesh refinement and smooth interface shape
Old   April 28, 2015, 12:37
Default Mesh refinement and smooth interface shape
Prosper is on a distinguished road
Hi All,
I am running a case where a droplet deforms in a surrounding fluid. I am able to generate a fine mesh around the interface to resolve the spherical interface. The refinement level for the mesh around the interface is 4.
The problem now is that I need a smooth interface shape because the problem is sensitive to interface force (interface tension driven flow). However, if you look at the interface closely (attached: alpha_t=0.jpg), you'll find small corners and non-smoothness on the interface. (I guess this is cause by the block meshes I used.) Because of these corners, I always get large variations in 'pressure' and 'initial velocity' variations around the interface. (see attached: p_t=0.jpg).
Could anyone tell me how can I get rid of those corners on the interface? Is there a 'smooth' function in OpenFOAM? Should I use even higher mesh levels? (I already have 200k cells...) Thank you for any suggestions!
Best,
-P
Prosper is offline   Reply With Quote
Old   May 4, 2015, 20:36
anonymous
ssss is on a distinguished road
You should try to improve the mesh, it seems to be pretty bad. Is it 2D or 3D?
ssss is offline   Reply With Quote
Old   May 5, 2015, 16:21
Thank you for your reply!
Yes I used finer meshes on the boundary and I ran the simulation with no external forces on the system, and try to let the variations in the curvature stabilize the surface shape. An the results seem pretty good. See attached.
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 05:17
[snappyHexMesh] Edge Refinement fracasce OpenFOAM Meshing & Mesh Conversion 3 December 2, 2017 14:30
[snappyHexMesh] Propeller mesh not smooth nortanapura OpenFOAM Meshing & Mesh Conversion 0 May 16, 2014 04:26
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
