[Gmsh] Changing the Mesh.RandomFactor in Gmsh
Old   April 28, 2015, 06:31
Exclamation Changing the Mesh.RandomFactor in Gmsh
Niko
Niko9310 is on a distinguished road
Hello everybody,
I try to mesh a driller's cross section with Gmsh via Matlab. For this I use the following code:
befehlsaufruf = [pfad '\gmsh ' pfad '\bohrer.geo ' '-2 -o ' pfad '\bohrer.msh'];
[status] = system (befehlsaufruf);
Unfortunately, it does not even work. Gmsh replies with an error:
Error : Identical points in triangulation: increase element size or Mesh.RandomFactor
I already changed the elementsize. But the elementsize does not solve the problem. Now I would like to test the Mesh.RandomFactor but I have no idea how to do it. Do you have an idea how to alter this Factor?
Thank you
kind regards
Niko9310
P.s.: I made some screenshots of bohrer.geo and the gmsh Error.
Niko9310 is offline   Reply With Quote
loading issue libraries:libsimpleFunctionObjects.so libsimpleSwakFunctionObjects.so immortality OpenFOAM Pre-Processing 15 April 7, 2024 13:35
[PyFoam] Problems with the new PyFoam release zfaraday OpenFOAM Community Contributions 13 December 9, 2014 19:58
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 08:18
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
