[snappyHexMesh] Running SnappyHexMesh - problem with refinement
Old   April 28, 2015, 06:22
Default Running SnappyHexMesh - problem with refinement
DOliveira is on a distinguished road
Hello, I am quite new at working with OpenFoam and I am with some doubts that maybe you can help me.
I am creating a mesh for a turbine using a STL file.
I run snappyHexMesh and I tried to refined my mesh by defining the 'searchableBox'
Every time I run snappyHexMesh now, after making the "Shell refinement iteration" it just starts "remove unreachable sections of mesh" and it doesn't do anything else for hours.
I don't know if you can help me but I would be grateful
DOliveira is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh Problem 96faizizzuddin OpenFOAM Meshing & Mesh Conversion 10 October 10, 2022 07:45
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
[snappyHexMesh] Problem in results with snappyHexMesh between refinement levels Phil_WO OpenFOAM Meshing & Mesh Conversion 2 November 8, 2018 04:49
[ICEM] Premesh refinement problem - Penetrating elements yonpanman ANSYS Meshing & Geometry 1 October 18, 2016 03:39
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
