[mesh manipulation] moveMesh with oscillatingInletACMI2D
Old   April 27, 2015, 13:33
Question moveMesh with oscillatingInletACMI2D
yardsail is on a distinguished road
The tutorial oscillatingInletACMI2D runs fine in my OpenFOAM 2.3.1, but if I try to run Allrun.pre and then moveMesh, I get this error:
--> FOAM FATAL IO ERROR:
keyword solver is undefined in dictionary "/home/username/OpenFOAM/username-2.3.1/run/oscillatingInletACMI2D/constant/dynamicMeshDict"
I also tried a modified case with mesh distortion instead of pure translation. This ran fine with moveMesh, except the cell points along the ACMI boundary did not move so that these cells became very skewed.
Any ideas on how to get oscillatingInletACMI2D to work with moveMesh?
Update:
Moving the mesh works fine with moveDynamicMesh instead of moveMesh. See this related post:
http://www.cfd-online.com/Forums/ope...namicmesh.html
No luck yet getting distorting meshes to work with ACMI though.
yardsail is offline   Reply With Quote
acmi, movemesh
[mesh manipulation] Generating nonuniform meshes with sizefunction alberto OpenFOAM Meshing & Mesh Conversion 28 July 31, 2017 18:50
cyclic boundary conditions and moveMesh gtg258f OpenFOAM 2 November 21, 2013 10:13
Dynamic moving mesh Pei-Ying Hsieh (Hsieh) OpenFOAM Running, Solving & CFD 64 June 7, 2012 11:04
moveMesh vs. moveDynamicMesh samiam1000 OpenFOAM 2 May 31, 2012 11:22
[Other] Surface aligned mesh rpasiok OpenFOAM Meshing & Mesh Conversion 6 January 7, 2008 06:55
