[blockMesh] Segmentation Fault BlockMesh
Old   April 22, 2015, 06:14
Default Segmentation Fault BlockMesh
nitw.deepak@gmail.com
DeepIndia is on a distinguished road
Hello All,
Can anyone suggest me some thing to resolve the error with my blockmesh dict, I am getting aerror of sedgementation fault.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.001;
vertices
    (0 0 0)
    (7 0 0)
    (32 0 0)
    (1118 0 0)//3
    (1118 10 0)//4
    (32 10 0)//5
    (7 10 0)//6
    (0 10 0)//7
    (0 15 0)//8
    (7 15 0)//9
    (32 15 0)
    (1118 15 0)//11
    (3118 0 0)//12
    (3118 2000 0)//13
    (1118 36 0)//14
    (1093 36 0)
    (1093 2000 0)//16
    (868 2000 0)//17
    (868 15 0)//18
    (1093 15 0)//19
    (0 0 -10)//20
    (7 0 -10)//21
    (32 0 -10)//22
    (1118 0 -10)//23
    (1118 10 -10)//24
    (32 10 -10)//25
    (7 10 -10)//26
    (0 10 -10)//27
    (0 15 -10)//28
    (7 15 -10)//29
    (32 15 -10)//30
    (1118 15 -10)//31
    (3118 0 -10)//32
    (3118 2000 -10)//33
    (1118 36 -10)//34
    (1093 36 -10)//35
    (1093 2000 -10)//36
    (868 2000 -10)//37
    (868 15 -10)//38
    (1093 15 -10)//39
blocks
      hex (0 1 6 7 20 21 26 27) (1 1 1) simpleGrading (1 1 1)
      hex (1 2 5 6 21 22 25 26) (1 1 1) simpleGrading (1 1 1)
      hex (2 3 4 5 22 23 24 25) (1 1 1) simpleGrading (1 1 1)
      hex (5 4 11 10 25 24 31 30) (1 1 1) simpleGrading (1 1 1)
      hex (6 5 10 9 26 25 30 29) ( 1 1 1) simpleGrading (1 1 1)
      hex (7 6 9 8 27 26 29 28) (1 1 1) simpleGrading (1 1 1)
      hex (3 12 13 14 23 32 33 34) (1 1 1) simpleGrading (1 1 1)//problem
      hex (14 13 16 15 34 33 36 35) (1 1 1) simpleGrading (1 1 1)
      hex (19 16 17 18 39 36 37 38) (1 1 1) simpleGrading (1 1 1)
edges
/* boundary
    atmboundaryinlet
        type patch;
        faces
            (12 32 33 13)
            (13 33 36 16)
            (16 36 37 17)
        (17 37 38 18)
    wallend
        type wall;
        faces
            (0 7 27 20)
        (7 8 28 27)
    transientgate
        type patch;//initially
    //type wall;//after some time
        faces
            (8 9 29 28)
    fixedWalls1
        type wall;
        faces
            (9 10 30 29)
            (10 18 38 30)
        (18 19 39 38)
        (19 15 35 39)
        (15 14 34 35)
        (11 31 34 14)
        fixedWalls2
        type wall;
        faces
            (18 38 39 19)
            (19 39 35 15)
        (15 35 34 14)
    frontAndBack
        type empty;
        faces
        (   (0 1 6 7)
        (7 6 9 8)
        (1 2 5 6)
            (6 5 10 9)
            (2 3 4 5)
            (5 4 11 10)
        (3 12 13 14)
            (14 13 16 15)
        (19 16 17 18)
        //back
        (20 27 26 21)
        (27 28 29 26)
        (21 26 25 22)
        (26 29 30 25)
        (22 25 23 24)
        (25 30 31 24)
        (23 34 33 32)
        (35 36 33 34)
        (38 37 36 39)
    bottom
        type symmetry;
        faces
        (   (0 20 21 1)
            (1 21 22 2)
        (2 22 23 3)
        (3 23 32 12)
mergePatchPairs
Last edited by wyldckat; April 23, 2015 at 15:01. Reason: Added [CODE][/CODE] markers and fixed typo in title
DeepIndia is offline   Reply With Quote
Old   April 23, 2015, 03:34
Jignesh Chokshi
Jimmy Chokshi is on a distinguished road
Hi Deepak,
Can you please post your error message ?
Jimmy Chokshi is offline   Reply With Quote
Old   April 28, 2015, 11:05
Hassan Kassem
hk318i is on a distinguished road
It isn't a big problem. you cannot comment the boundary list. I edited it for you in red.
Also note that, it just one mesh cell for each block. You have add more cells in x and y directions and it should be consistent with across the blocks boundaries. Otherwise, you will have to use the mergePatchPairs option.
Bw,
Hassan
Originally Posted by DeepIndia View Post
Hello All,
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
vertices
    (0 0 0)
    (7 0 0)
    (32 0 0)
    (1118 0 0)//3
    (1118 10 0)//4
    (32 10 0)//5
    (7 10 0)//6
    (0 10 0)//7
    (0 15 0)//8
    (7 15 0)//9
    (32 15 0)
    (1118 15 0)//11
    (3118 0 0)//12
    (3118 2000 0)//13
    (1118 36 0)//14
    (1093 36 0)
    (1093 2000 0)//16
    (868 2000 0)//17
    (868 15 0)//18
    (1093 15 0)//19
    (0 0 -10)//20
    (7 0 -10)//21
    (32 0 -10)//22
    (1118 0 -10)//23
    (1118 10 -10)//24
    (32 10 -10)//25
    (7 10 -10)//26
    (0 10 -10)//27
    (0 15 -10)//28
    (7 15 -10)//29
    (32 15 -10)//30
    (1118 15 -10)//31
    (3118 0 -10)//32
    (3118 2000 -10)//33
    (1118 36 -10)//34
    (1093 36 -10)//35
    (1093 2000 -10)//36
    (868 2000 -10)//37
    (868 15 -10)//38
    (1093 15 -10)//39
blocks
edges
 boundary
    atmboundaryinlet
        type patch;
        faces
            (12 32 33 13)
            (13 33 36 16)
            (16 36 37 17)
        (17 37 38 18)
    wallend
        type wall;
        faces
            (0 7 27 20)
        (7 8 28 27)
    transientgate
        faces
            (8 9 29 28)
    fixedWalls1
        type wall;
        faces
            (9 10 30 29)
            (10 18 38 30)
        (18 19 39 38)
        (19 15 35 39)
        (15 14 34 35)
        (11 31 34 14)
        fixedWalls2
        type wall;
        faces
            (18 38 39 19)
            (19 39 35 15)
        (15 35 34 14)
    frontAndBack
        type empty;
        faces
        (   (0 1 6 7)
        (7 6 9 8)
        (1 2 5 6)
            (6 5 10 9)
            (2 3 4 5)
            (5 4 11 10)
        (3 12 13 14)
            (14 13 16 15)
        (19 16 17 18)
        //back
        (20 27 26 21)
        (27 28 29 26)
        (21 26 25 22)
        (26 29 30 25)
        (22 25 23 24)
        (25 30 31 24)
        (23 34 33 32)
        (35 36 33 34)
        (38 37 36 39)
    bottom
        type symmetry;
        faces
        (   (0 20 21 1)
            (1 21 22 2)
        (2 22 23 3)
        (3 23 32 12)
mergePatchPairs
hk318i is offline   Reply With Quote
[blockMesh] Segmentation Fault when creating block mesh topography (blockMesh) jbrydg01 OpenFOAM Meshing & Mesh Conversion 2 May 11, 2017 06:37
Segmentation fault in SU2 V5.0 ygd SU2 2 March 1, 2017 05:38
Segmentation fault when running in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 8, 2015 09:12
Segmentation Fault w/ compiled OF 2.2.0 - motorBike example sudo OpenFOAM Running, Solving & CFD 3 April 2, 2013 18:27
segmentation fault when installing OF-2.1.1 on a cluster Rebecca513 OpenFOAM Installation 9 July 31, 2012 16:06
