[blockMesh] blockMesh from scratch - how to visualize it on Paraview? |
Lisandro Maders
Rep Power: 13 ![]() |
The main problem is:
how can I see the mesh I have just created using blockMesh command on paraview, without having all the case files (like fvSchemes, fvSolution, 0 folder files, etc..). The only thing I have is the blockMeshDict file as well as the points, faces, owners, etc. files that were generated with blockMesh. Having only those files, how can I visualize my mesh? Regards, Lisandro |
Amod Kumar
Rep Power: 16 ![]() |
One does not need the fvscheme and other filed. The file generated by blockMesh is good enough. The method I always follow is (I am using Windows version of OF): 1. create an empty file in <casename>.openFOAM, where <casename> without <> is the name of the case such as "Test". 2. Place it in the folder along with the 0/, constant/ and system/ directory. 3. Open the file <casename>.openFOAM in Paraview (select file type "all files" and them type "openFOAM". You may like to refer to the file http://www.cfdyna.com/Home/OpenFOAM_Tut.pdf Regards, Amod |
Alexander Bartel
Rep Power: 11 ![]() |
@mods: Could be merged with http://www.cfd-online.com/Forums/ope...tml#post539525
@Lisandro: perhaps I got your Problem. You have to type "paraFoam" in the case folder after copying just any fvSchemes and fvSolution file from any tutorial you want. regards Alex |
Lisandro Maders
I just saw your message now. I have solved the problem and it was exactly this. I didn't have the fvS* files in my case directory...
Thanks anyway! Lisandro |
blockmesh, parafoam, paraview, visualization, visualize grid |
visualize a system of particles in tecplot or paraview | mnajafi | FieldView | 0 | October 13, 2018 16:02 |
[OpenFOAM.org] Two different versions of ParaView with same OpenFOAM release | FJSJ | OpenFOAM Installation | 2 | July 23, 2017 06:48 |
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) | chrisb2244 | OpenFOAM Installation | 2 | August 21, 2013 14:24 |
[General] paraview ignores SPACING in STRUCTURED_POINTS vtk data? | jaffar | ParaView | 0 | November 27, 2012 10:36 |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 08:11 |
