[snappyHexMesh] Snap generates holes in the mesh
Old   March 25, 2015, 04:20
Default Snap generates holes in the mesh
Svensen is on a distinguished road
On the snap stage of the snappyHexMesh a lot of warning occurred like:
"FOAM Warning : Displacement (0.000471899 0.000534394 0.000778924) at mesh point 54635 coord (6.23573 -3.19009 12.8464) points through the surrounding patch faces"
As a results the final mesh contains some strange holes... but castellated mesh was OK.
The screenshot is attached.
Svensen is offline   Reply With Quote
meshing issues, openfoam 2.3.0, snappyhexmesh
[snappyHexMesh] Multi Region Mesh of a car filter Zephiro88 OpenFOAM Meshing & Mesh Conversion 3 September 11, 2019 20:34
[TurboGrid] Holes and overlap of Mesh elements in Shroud Region vishwasvemra ANSYS Meshing & Geometry 0 July 12, 2017 02:39
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
