March 19, 2015, 11:55 |
Remeshing for a free fall object
GL
I'm trying to manage to simulate a falling object (solid) in a homogeneous liquid (like water and later LBe). To manage this kind of simulation, I need several solvers : "- a fluid flow solver with support for moving meshes; - force calculation on the boundary; - a 6-DOF solver that can calculate the position/motion based on the forces and intertial parameters. This will determine the boundary motion for you; - an automatic mesh motion solver, which will deform the mesh based on prescribed boundary motion." (Citation from Hrvoje Jasak) I had a look during the 2 last months on this forum to try to figure out how to do. I'm not a pro OpenFOAM and my time is running out. What I have done :
So in the 2 first cases, I'm stuck and I can't go ahead. My level in OF do not allow me to change solvers. I'm wondering if anyone has done this kind of job before and can help me? Do you think it's possible to manage that? I highly thanks you for your help, Sincerely yours, Gauthier |
March 22, 2018, 03:43 |
Did it succeed?
KuifengZhao
Hi GauthierL,
Did it work at last? I am interested to see how the falling object is to be simulated. |
August 22, 2018, 09:37 |
kk
Hi GauthierL,
I just started learning openfoam.I am doing the simulation of falling objects. Have you solved your problem? thanks. |
remeshing topochanger |
[swak4Foam] difficulties installing swak4foam | newbie29 | OpenFOAM Community Contributions | 120 | October 21, 2022 05:01 |
Free Fall CEL Definition | kanaha | CFX | 7 | January 16, 2018 17:54 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 08:36 |
OpenFOAM141dev linking error on IBM AIX 52 | matthias | OpenFOAM Installation | 24 | April 28, 2008 16:49 |
Dynamic Grid Remeshing causing Divergence? | Andrew Wick | FLUENT | 0 | January 23, 2006 19:39 |
