[Other] Mesh from OF23x to OF3.1ext. Error of format
Old   March 11, 2015, 13:25
Default Mesh from OF23x to OF3.1ext. Error of format
M. Montero
be_inspired is on a distinguished road
Hi all,
Using the same mesh made with snappy into OF23X, I get an error when using checkMesh into OF3.1-ext.
--> FOAM FATAL IO ERROR:
unexpected class name faceCompactList expected faceList
while reading object faces
I have changed faceCompactList to faceList and a different error happens:
incorrect first token, expected <int> or '(', found on line 20 an error
When trying to launch snappy directly on OF3.1-ext I get a segmentation fault error with no more information about why.
I would like to try pimpleDyMFoam implementation on OF3.1 ext.
Thank you
be_inspired is offline   Reply With Quote
Old   March 18, 2015, 05:03
W.T
dybuk is on a distinguished road
I have similar problem when I try to change version of OF and mesh is written in binary format. When files are written in ascii format everything is ok.
dybuk is offline   Reply With Quote
Old   January 16, 2017, 03:39
Vaze
mvee is on a distinguished road
I have similar problem. I saved file in ascii format but problem persists. Do you have any other option to work on?
Thank you
Mvee
mvee is offline   Reply With Quote
Old   January 16, 2017, 06:13
W.T
Hi
There is a tool "compactFaceToFace" wich converts constant/polyMesh/faces file from compactList (default in OpenFOAM) to standard list (foam-extended).
Tool can be found here:
https://www.cfd-online.com/Forums/op...mpactlist.html
[Commercial meshers] ICEM mesh file in correct format for OpenFOAM SamEngD OpenFOAM Meshing & Mesh Conversion 0 April 5, 2017 07:29
[snappyHexMesh] Snappyhex mesh: poor inlet mesh Swagga5aur OpenFOAM Meshing & Mesh Conversion 1 December 3, 2016 17:59
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
