[snappyHexMesh] not symmetric mesh around symmetric geometry
Old   March 4, 2015, 14:03
Default not symmetric mesh around symmetric geometry
Lefteris
Aeronautics El. K. is on a distinguished road
Hello all.
I'm trying to mesh an airplane which is obviously symmetrical along the centreline.
I've tried quite a few different things:
a. take the whole aircraft and have blockMesh chop-off the right half of the airplane
b. take the whole aircraft and have blockMesh chop-off the left half of the airplane
c. mesh the whole airplane as it is
I'm running snappyHexMesh in parallel.
In every single case that I've tried, the right and left part of the mesh are not symmetric as one would expect. This is especially surprising in the case of the full aircraft.
The problem is around the trailing edges which get better resolved on one side of the aircraft but not on the other (or either the left-mesh or the right-mesh).
Explicit or implicit feature extract doesn't seem to have any effect.
Does anyone have any idea why this might be happening?
ps
I'm currently running another case with exactly the same case but on one processor to see if that makes any difference.
Lefteris
Aeronautics El. K. is offline   Reply With Quote
Old   May 23, 2020, 03:51
Grivalszki Péter
GrivalszkiP is on a distinguished road
Hi!
Have you solved the problem? If yes, how?
GrivalszkiP is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 18:16
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 05:17
[ICEM] Problems with structured mesh in IcemCFD symmetric problem jexposito ANSYS Meshing & Geometry 3 December 19, 2015 06:34
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
