[blockMesh] Total number of faces on empty patches is not divisible by the number of cells in the |
ankit
Rep Power: 0 ![]() |
Hi I am new to OpenFOAM, I am trying to simulate flow over cylinder problem. But I'm facing issues in generating mesh as the above error keeps on popping (Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D). I am pasting my blockMeshDict file, please give your valuable suggestions.
vertices ( (-20 -25 0) (20 -25 0) (40 -25 0) (-0.7071 -0.7071 0) (0.7071 -0.7071 0) (-0.7070 0.7071 0) (0.7071 0.7071 0) (-20 25 0) (20 25 0) (40 25 0) (-20 -25 1) (20 -25 1) (40 -25 1) (-0.7071 -0.7071 1) (0.7071 -0.7071 1) (-0.7071 0.7071 1) (0.7071 0.7071 1) (-20 25 1) (20 25 1) (40 25 1) ); blocks ( hex (0 3 5 7 10 13 15 17) (10 10 1) simpleGrading (1 1 1) hex (1 4 3 0 11 14 13 10) (10 10 1) simpleGrading (1 1 1) hex (4 1 8 6 14 11 18 16) (10 10 1) simpleGrading (1 1 1) hex (6 8 7 5 16 18 17 15) (10 10 1) simpleGrading (1 1 1) hex (1 2 9 8 11 12 19 18) (10 10 1) simpleGrading (1 1 1) ); edges ( ); patches ( ); mergePatchPairs ( ); |
Alexander Bartel
Rep Power: 11 ![]() |
Hi ankit,
i think you have to define the boundary like in the Users Guide (http://www.openfoam.org/docs/user/blockMesh.php). Otherwise the faces are set as empty patches. Empty patches are useful to define symmetry planes in case of 1D or 2D meshes. greetings Alex |
ankit
Thanks alex,
Pardon me, but is it really necessary to define boundary conditions for a mesh generation? cause I'd watched few online tutorials and they didn't mention anything about boundary condition for mesh generation only. |
Alexander Bartel
You are right.
You don t need boundary conditions for the mesh generation. But your boundary has to be defined properly. So you have to tell OF what kind of walls or borders your mesh has, otherwise OF suggest the simplest kind of border for them all (empty as seen in your error message). But you don t have to tell OF the values of the different fields (e.g. U, T, p ...) in the mesh, because you don t want to compute any fields yet. |
AmiN
I converted gmsh file with Openfoam and changed the boundary type to empty to get a 2D msh , but check mesh is failed [before was ok]
Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D. what can be done? Code:
Time = 0 Mesh stats points: 236270 internal points: 0 faces: 819496 internal faces: 349439 cells: 233787 faces per cell: 5 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 1 Overall number of cells of each type: hexahedra: 0 prisms: 233787 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. ***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology backAndFront 467574 236270 ok (non-closed singly connected) bottumWall 968 1938 ok (non-closed singly connected) inlet 100 202 ok (non-closed singly connected) topWall 700 1402 ok (non-closed singly connected) outlet 100 202 ok (non-closed singly connected) defaultFaces 615 1230 ok (non-closed singly connected) Checking faceZone topology for multiply connected surfaces... No faceZones found. Checking basic cellZone addressing... CellZone Cells Points Volume BoundingBox vol 233787 236270 170.959 (-10 0 0) (25 5 1) Checking geometry... Overall domain bounding box (-10 0 0) (25 5 1) Mesh has 1 geometric (non-empty/wedge) directions (1 0 0) Mesh has 1 solution (non-empty) directions (1 0 0) ***Number of edges not aligned with or perpendicular to non-empty directions: 700066 <<Writing 236270 points on non-aligned edges to set nonAlignedEdges Boundary openness (-5.67172e-18 -3.08512e-16 -3.24846e-23) OK. Max cell openness = 1.86187e-16 OK. Max aspect ratio = 1 OK. Minimum face area = 3.21874e-05. Maximum face area = 0.069087. Face area magnitudes OK. Min volume = 3.21874e-05. Max volume = 0.0015201. Total volume = 170.959. Cell volumes OK. Mesh non-orthogonality Max: 29.5829 average: 3.28355 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.478616 OK. Coupled point location match (average 0) OK. Failed 1 mesh checks. End |
Pramod Kashyap
I had the same issue with "***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D." I have attached the blockMeshDict file and checkMesh log file here - log.checkmesh file - Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 234421 faces: 654100 internal faces: 605900 cells: 210000 faces per cell: 6 boundary patches: 5 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 210000 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. ***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 1000 1111 ok (non-closed singly connected) outlet 1000 1111 ok (non-closed singly connected) top 2100 2321 ok (non-closed singly connected) hillGround 2100 2321 ok (non-closed singly connected) frontAndBack 42000 42622 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-20 0.5 0) (25 25 10) Mesh has 2 geometric (non-empty/wedge) directions (1 1 0) Mesh has 2 solution (non-empty) directions (1 1 0) All edges aligned with or perpendicular to non-empty directions. Boundary openness (1.585055e-17 -5.3718505e-15 -1.8733849e-14) OK. Max cell openness = 2.3241059e-16 OK. Max aspect ratio = 6.2306125 OK. Minimum face area = 0.0053744038. Maximum face area = 0.62424545. Face area magnitudes OK. Min volume = 0.0053744038. Max volume = 0.23409204. Total volume = 10936.61. Cell volumes OK. Mesh non-orthogonality Max: 32.871842 average: 9.856776 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.29386884 OK. Coupled point location match (average 0) OK. Mesh OK. End blockMeshDict file - H 2.5; vertices ( ( -20 0.5 0 ) // 0 ( -5 0.5 0 ) // 1 ( 5 0.5 0 ) // 2 ( 25 0.5 0 ) // 3 ( 25 25 0 ) // 4 ( 5 25 0 ) // 5 ( -5 25 0 ) // 6 ( -20 25 0 ) // 7 ( -20 0.5 10 ) // 8 ( -5 0.5 10 ) // 9 ( 5 0.5 10 ) // 10 ( 25 0.5 10 ) // 11 ( 25 25 10 ) // 12 ( 5 25 10 ) // 13 ( -5 25 10 ) // 14 ( -20 25 10 ) // 15 ); blocks ( // Medium level for tutorial hex ( 0 8 9 1 7 15 14 6 ) (10 40 100) simpleGrading (1 1 10) hex ( 1 9 10 2 6 14 13 5 ) (10 100 100) simpleGrading (1 1 10) hex ( 2 10 11 3 5 13 12 4 ) (10 70 100) simpleGrading (1 1 10) ); edges #codeStream { codeInclude #{ #include "pointField.H" #include "mathematicalConstants.H" #}; code #{ const scalar xMin = -5; const scalar xMax = 5; const label nPoints = 1000; const scalar dx = (xMax - xMin)/scalar(nPoints - 1); os << "(" << nl << "spline 1 2" << nl; pointField profile(nPoints); const scalar pi = constant::mathematical: ![]() for (label i = 0; i < nPoints; ++i) { scalar x = xMin + i*dx; profile[i].x() = x; profile[i].y() = pow($H,3)/(pow($H,2)+pow(x,2)); profile[i].z() = 0; } os << profile << nl; os << "spline 9 10" << nl; profile.replace(2, 10); os << profile << nl; os << ");" << nl; #}; }; boundary ( inlet { type patch; faces ( ( 0 8 15 7 ) ); } outlet { type patch; faces ( ( 4 12 11 3 ) ); } top { type symmetryPlane; faces ( ( 6 7 15 14 ) ( 5 6 14 13 ) ( 4 5 13 12 ) ); } hillGround { type wall; faces ( ( 0 1 9 8 ) ( 1 2 10 9 ) ( 2 3 11 10 ) ); } frontAndBack { type empty; faces ( ( 14 15 8 9 ) ( 13 14 9 10 ) ( 12 13 10 11 ) ( 7 6 1 0 ) ( 6 5 2 1 ) ( 5 4 3 2 ) ); } ); mergePatchPairs ( ); Can someone please help me out with this? Thank you in advance |
edges |
[snappyHexMesh] Layers not growing at all | zonda | OpenFOAM Meshing & Mesh Conversion | 12 | June 6, 2020 11:28 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 03:58 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
