[snappyHexMesh] Sanity check on snappyHexMesh with SwiftSnap/Blender |
January 8, 2015, 17:45 |
Louis S
Rep Power: 14 |
I'm trying to get my feet wet in electrostatic simulation, and was able to run the basic charged wire example. To try and take it further, I made a torus in a cube using Blender and SwiftSnap, and am trying to run the simulation to see the distribution of the field between the two objects.
However, whenever I run the simulation, I only get a uniform cube (although blockMesh, snappyHexMesh, electrostaticFoam, and paraFoam seem to run with no errors). Based on the SwiftSnap pipe example, it seemed like I should make the box faces a mesh, and the taurus outside a seperate patch. Is there something else required to tell snappyHex to use the volume between the two patches? Thanks, Louis |
January 12, 2015, 11:47 |
Louis S
Rep Power: 14 |
After speaking with papna on #openfoam-irc, I was able to get the internal geometry to show up in paraFoam by increasing the blockMesh resolution. In blockMeshDict, I changed the following line:
hex (4 5 6 7 0 1 2 3) (2 2 2) simpleGrading (1 1 1) to: hex (4 5 6 7 0 1 2 3) (8 8 8) simpleGrading (1 1 1) However, even though electrostaticFoam runs and solves rho and phi with no residuals, there is no volume data for rho or phi after timestep 0. |
blender, swiftsnap |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 03:54 |
[snappyHexMesh] Parallelize snappyHexMesh optimally? | Antimony | OpenFOAM Meshing & Mesh Conversion | 1 | May 25, 2016 01:01 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 03:55 |
[snappyHexMesh] snappyHexMesh runs endless - I need general advise | TeresaT | OpenFOAM Meshing & Mesh Conversion | 5 | November 17, 2015 03:50 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 03:09 |
