[Gmsh] Gmsh. I want a mesh with Quadrangle (9 nodes instead of 8 nodes)
Old   December 13, 2014, 16:59
Default Gmsh. I want a mesh with Quadrangle (9 nodes instead of 8 nodes)
Guiliguili
Touré is on a distinguished road
I tried the Transfinite Surface "*" and Recombine Surface "*" to get Quadrangle9 but I still obtained 8 nodes instead of 9 nodes.
Please, how do I get only Quadrangle9 elements as illustrated below with gmesh command line?
3-----6-----2
7-----8-----5
0-----4-----1
Thanks.
Touré is offline   Reply With Quote
Old   July 5, 2016, 07:48
Default 8 node quads mesh
Tshering Lhamo
Tshering is on a distinguished road
Hello, I don't know if it's too late. However, I wanted to ask if it is possible to generate 8 node quads elements mesh with GMSH. I have a file from Lagamine with only 8 node elements. Thank you
Tshering is offline   Reply With Quote
Old   June 23, 2017, 13:17
Guiliguili
If it's not too late you need a second order element (Check at http://gmsh.info/doc/texinfo/gmsh.ht...r-options-list)
Does Gmsh support curved elements? Yes, Gmsh can generate both 1st order and 2nd order elements. To generate second order elements, click on ‘High order’ in the mesh menu after the mesh is completed. To always generate 2nd order elements, select ‘Generate second order elements’ in the mesh option panel. From the command line, you can also use -order 2.
If you're using the command line, you will need first to combine triangles into rectangles by using Recombine function in the geometry file:
Recombine Surface { expression-list } | "*" < = expression >; Recombines the triangular meshes of the surfaces listed in expression-list into mixed triangular/quadrangular meshes. The optional expression on the right hand side specifies the maximum difference (in degrees) allowed between the largest angle of a quadrangle and a right angle (a value of 0 would only accept quadrangles with right angles; a value of 90 would allow degenerate quadrangles; default value is 45).
At last, from a command line:
gmsh t1.geo -3 -order 2 mesh.msh
where
t1.geo is you geometry file
-2 for a 2D
-order 2 for a second order element (-order int: set mesh order(1, ..., 5))
mesh.msh is the name of your output file
[Other] Dynamic Mesh: Morph internal mesh nodes nucat OpenFOAM Meshing & Mesh Conversion 0 September 15, 2014 12:04
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[Gmsh] background mesh in gmsh Nick_J OpenFOAM Meshing & Mesh Conversion 1 March 20, 2013 05:20
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
