[Salome] Create CellZones in an UNV Mesh
Old   October 28, 2014, 16:31
Default Create CellZones in an UNV Mesh
Esteban Vargas
vbesteban is on a distinguished road
Hi.
I'm working in a propeller simulation. But I have several problems to create my cellZones dict to generate the rotation in my case.
I'm working with simpleFoam, and generate the rotation with MRFZones in my fvOptions dict in System folder, but I don't really know how to create my cellZones.
I've already generated my mesh in salome, and then exported into OF, but this export doesn't generate any cellZone. In salome I just generate a mesh waiting for create my cellzones in OF. I'm looking for rotate the propeller.
I attach the file of my case.
https://www.dropbox.com/s/nu6d9v4fsm...er.tar.gz?dl=0
vbesteban is offline   Reply With Quote
Old   October 28, 2014, 16:38
Default Using OF 2.3
Esteban Vargas
An additional comment, I'm using OF 2.3
Old   June 7, 2019, 14:47
spike
spikespigel is on a distinguished road
Originally Posted by vbesteban View Post
Hi.
good afternoon
I have the same problem, could you solve it?
I really appreciate your help
spikespigel is offline   Reply With Quote
Old   June 10, 2019, 23:18
Yehezkiel Wiliardy
yewi is on a distinguished road
i usually use MRFproperties inside the constant folder instead
it looks something like this
|  \\    /   O peration     | Version:  4.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      MRFProperties;
rotor
    cellZone    rotor;
    active      yes;
    // Fixed patches (by default they 'move' with the MRF zone)
    nonRotatingPatches ();
    origin    (0 0 0);
    axis      (0 0 1); //axis of rotation
    omega     constant 1047.2; //rotation in rad/s
also in your snappyHexMeshDict, you can specify this rotating zone as follow
geometry
rotor
        type            searchableCylinder;
        point1          (0 0 0); //start of zone center
        point2          (0 0 1); //height of zone
        radius          3.00; //radius of zone
//modify this to setup your zone
castellatedMeshControls
    refinementSurfaces
        rotor
            level           (7 8);
            faceType        internal;
            cellZone        rotor;
            faceZone        rotor;
            cellZoneInside  inside;
cheers,
yewi
yewi is offline   Reply With Quote
Old   June 17, 2022, 13:46
aeronerd is on a distinguished road
Doesn't the use of snappyHexMeshDict imply that this cellzone will only be created if the geometry is meshed with snappy hex mesh? I too would like to import a mesh from Salome and define the MRF cellzone for purposes of spinning a propeller.
Or does this leave the mesh untouched, but use snappyHexMesh somehow to only define a cellzone?
aeronerd is offline   Reply With Quote
Old   June 18, 2022, 16:01
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
If you want to use Salome for multizone meshing you can follow this tutorial.
https://www.youtube.com/watch?v=NYEU6ALOtJk
Key is to have a compound of solids that create "Groups of Volumes".
ideasUnvToFoam will use those groups to create cellZones.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
SonicFoam tuto nacaAirfoil steadystate Dorian1504 OpenFOAM Running, Solving & CFD 10 October 11, 2017 18:05
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
