[snappyHexMesh] Addlayers and refined edges (snappyHexMesh)
Old   October 25, 2014, 10:00
Default Addlayers and refined edges (snappyHexMesh)
Max Foamer
Max Foamer is on a distinguished road
I have been trying to add layers to an Ahmed body with refined edges, but the layers collapse at the refined edges. Any suggestions?
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh false;    // make basic mesh ?
snap            false;    // decide to snap back to surface ?
addLayers       true;  // decide to add viscous layers ?
geometry // Load in STL files here
    Ahmedm.stl {type triSurfaceMesh; name Ahmedm;}
    refinementBox1 {type searchableBox; min (-0.4 -0.3 0); max ( 1 0.3 0.35);}
    refinementBox2 {type searchableBox; min (-1.444 -0.935 0); max ( 6.264 0.935 0.002);}
castellatedMeshControls
    maxLocalCells 10000000;  //max cells per CPU core
    maxGlobalCells 200000000; //max cells to use before mesh deletion step
    minRefinementCells 0;  //was 0 - zero means no bad cells are allowed during refinement stages
    maxLoadUnbalance 0.1;
    nCellsBetweenLevels 1;  // expansion factor between each high & low refinement zone
    // Explicit feature edge refinement
    features // taken from STL from each .eMesh file created by "SurfaceFeatureExtract" command
        {file "Ahmedm.eMesh"; level 9;}
    // Surface based refinement
    refinementSurfaces // Surface-wise min and max refinement level
    Ahmedm {level (4 6);}
    Ground {level (4 4);}
    Inlet {level (0 4);}
    Outlet {level (0 4);}
    //SymT  {level (0 4);}
    SymR {level (0 4);}
    SymL {level (0 4);}
    resolveFeatureAngle 160;  // Resolve sharp angles // Default 30
    refinementRegions        // In descending levels of fine-ness
    Ahmedm {mode distance;  levels ((0.01 5)(0.02 4) (0.2 3) (0.5 2) (0.7 1));} //((0.0003 5)(1. 4) (1.3 3) (2. 1));}
    //Ground {mode distance;  levels ((0.02 4) (0.2 3) (0.5 2) (0.6 1));}
    refinementBox1 {mode inside; levels ((3 3));}
    refinementBox2 {mode distance;  levels ((0.01 4) (0.05 3) (0.08 2) (0.5 1));}
    //refinementBox2 {mode inside; levels ((3 3));}
      } // was ((0.001 4) (0.003 3) (0.01 2))
    locationInMesh (-1.2545 0 0.5314);  //to decide which side of mesh to keep **
    allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
    nSmoothPatch 3;
    tolerance 3;
    nSolveIter 300;
    nRelaxIter 7;
    nFeatureSnapIter 13; // default is 10
// New settings from openfoam 2.2 onwards for SHMesh
implicitFeatureSnap false; // default is false - detects without doing surfaceFeatureExtract
explicitFeatureSnap true; // default is true
multiRegionFeatureSnap true; // deafault is false - detects features between multiple surfaces
// Settings for the layer addition.
addLayersControls //add the PATCH names from inside the STL file so STLpatchName_insideSTLName
    relativeSizes false; // was true
    layers
    Ahmedm
             {nSurfaceLayers 4;} // was 3
    Ground
        {nSurfaceLayers 4;}
    expansionRatio 2;
    finalLayerThickness 0.00085; //was 0.00016
    minThickness 0.0000025; //was 0.00008
    nGrow 0; // was 1
    // Advanced settings
    featureAngle 160; // was 70 //- When not to extrude surface. 0 is flat, 90 is right angle.
    nRelaxIter 3;  //- Max# of snapping relaxation iter. Should stop before upon reaching a correct mesh.
    nSmoothSurfaceNormals 5;  // Number of smoothing iterations of surface normals
    nSmoothNormals 7; // Number of smoothing iterations of interior mesh movement direction
    nSmoothThickness 15;  // Smooth layer thickness over surface patches
    maxFaceThicknessRatio 0.7; // Stop layer growth on highly warped cells
    maxThicknessToMedialRatio 0.7; // Reduce layer growth where ratio thickness to medial distance is large
    minMedianAxisAngle 80;  // Angle used to pick up medial axis points
    nBufferCellsNoExtrude 0;   // Create buffer region for new layer terminations
    nLayerIter 100; // Overall max number of layer addition iterations
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    maxNonOrtho 80;
    maxBoundarySkewness 20;
    maxInternalSkewness 4;
    maxConcave 30;
    minFlatness 0.5;
    minVol 1e-13;
    minTetQuality 1e-9;
    minArea -1;
    minTwist 0.02;
    minDeterminant 0.001;
    minFaceWeight 0.02;
    minVolRatio 0.01;
    minTriangleTwist -1;
    // Advanced
    nSmoothScale 4;
    errorReduction 0.75;
// Advanced
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1E-6;
File Type: jpg Screenshot from 2014-10-25 14:49:20.jpg (66.6 KB, 135 views)
Max Foamer is offline   Reply With Quote
edges, snappyhexmesh
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 09:26
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 18:16
[snappyHexMesh] snappyHexMesh creates inverted meshes emat OpenFOAM Meshing & Mesh Conversion 3 March 27, 2017 09:50
[snappyHexMesh] collapsed edges snappyHexMesh ynos OpenFOAM Meshing & Mesh Conversion 1 April 16, 2014 09:23
[snappyHexMesh] SnappyHexMesh Internal Flow Example (Diesel Injector) Irish09 OpenFOAM Meshing & Mesh Conversion 23 July 15, 2013 08:45
