[Other] modelling & meshing of submerged pipe
Old   October 24, 2014, 11:31
Question modelling & meshing of submerged pipe
Simon Zhang
simonsg is on a distinguished road
Hi all,
I want to simulate flow discharged from a partly submerged pipe into a domain (see attachment). The upper top of the pipe is the inlet and the lower is open though which the flow can go to the outer domain. The curved surface of the pipe is a wall with no thickness. I attempted to use snappyHexMesh tool to insert this pipe into the block but it always cut off the outer part of the pipe.
Is there anyone dealing with this type of geometry before? Is it possible to make it using existing OF tools? If yes, how? I look forward to your comments.
Thanks,
Simon
simonsg is offline   Reply With Quote
Difficulties in meshing Big Kahuna Main CFD Forum 1 April 16, 2018 01:42
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
[ICEM] Simple pipe meshing - problems with y+ in CFX Keizers ANSYS Meshing & Geometry 23 January 15, 2015 09:00
[ICEM] Meshing a complex pipe network Industrial_CFD ANSYS Meshing & Geometry 0 January 31, 2012 16:59
[GAMBIT] Meshing a pipe vedravi ANSYS Meshing & Geometry 1 March 25, 2010 14:19
