[blockMesh] Wedge-shaped block: Problem with skew faces |
Rep Power: 12 ![]() |
Hi there,
I've created a mesh of a Wave Channel using wedge-shaped blocks. In the attached pictures you can see the geometry of the whole domain, the blockMeshDict and the error message of the checkMesh utility. I think the nonOrthoFaces shouldn´t be a problem. Can I also ignore the zeroAreaFaces as it's normal to have zeroAreaFaces in a wedgeshaped block? The Tutorial states these block faces would be assigned to a patch, which then can be seen as a patch with no faces in the boundary file. But there is no such patch in the boundary file for my case. Also checkMesh detects two skewFaces. I've looked at them with ParaView and they are on the downside face of the wedge-shaped block (the ZeroAreaFace) left side of the structure. (see the red line on the attached zoomed-in picture) I'm wondering:
Rep Power: 16 ![]() |
in my opinion you should avoid the wedge-shaped blocks. Try to create your blocks as shown in the attached image. This way you will obtain a mesh consisting of real quads/hexas only. Cutter |
now with all the three images I created:
skew faces, wedge block, zero area faces |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Problem with building geometry - concentric cylinders | Rhoddwen | OpenFOAM Pre-Processing | 9 | December 17, 2014 10:02 |
Problem with geometry - concentric cylinders | Rhoddwen | OpenFOAM Running, Solving & CFD | 0 | December 15, 2014 09:22 |
