[snappyHexMesh] Order of snappyHexMesh and decomposePar |
October 20, 2014, 09:29 |
Litao
Rep Power: 15 |
Hi FOAMers,
I have this question in my mind, but haven't figure out answer yet, so please help me. Say if I have a geometry needs to be decomposed into 8 processor sub-domains, and I'm just curious if the order of running 'snappyHexMesh' and 'decomposePar' would make any difference on the mesh. I image that if I decompose the domain first, then the mesh has to align itself with the separating boundary faces/lines; and if I do snappyHexMesh first, the decomposePar will take place based on the orthogonal or other criteria? I'm not sure if this is correct, and which way is the best to give the better mesh, so FOAMers, please advice, thanks! |
November 11, 2018, 05:15 |
You should run decomposePar before snappyHexMesh
So the snappyHexMesh will also run in parallel.
The snappyHexMesh will move cells from one processor to another in order make the number of cells almost the same. |
decomposepar, snappyhexmesh |
[snappyHexMesh] Problem with decomposePar, snappyHexMesh | luca1992 | OpenFOAM Meshing & Mesh Conversion | 12 | August 23, 2017 19:06 |
[snappyHexMesh] snappyHexMesh "face ... area does not match neighbour by ..." error | kbziya | OpenFOAM Meshing & Mesh Conversion | 0 | August 3, 2016 13:09 |
[snappyHexMesh] Parallelize snappyHexMesh optimally? | Antimony | OpenFOAM Meshing & Mesh Conversion | 1 | May 25, 2016 00:01 |
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? | klausb | OpenFOAM Meshing & Mesh Conversion | 1 | March 7, 2015 11:55 |
[snappyHexMesh] ReconstructParMesh after parallel snappyHexMesh | kawechel | OpenFOAM Meshing & Mesh Conversion | 6 | March 2, 2013 05:47 |
