[Other] ideasUnvToFoam for flow past cylinder |
October 3, 2014, 07:33 |
rafath
Rep Power: 12 |
Hi all,
I am new to openfoam. I used Salome to generate geometry for flow past cylinder and when converting in OpenFOAM the following error occurred. Please Help.. " Create time Processing tag:2411 Starting reading points at line 3. Read 31080 points. Processing tag:2412 Starting reading cells at line 62166. First occurrence of element type 11 for cell 1 at line 62167 First occurrence of element type 44 for cell 165 at line 62659 First occurrence of element type 115 for cell 2089 at line 66671 Read 14000 cells and 31040 boundary faces. Processing tag:2467 Starting reading patches at line 165929. For group 1 named right trying to read 14400 patch face indices. For group 2 named left trying to read 14400 patch face indices. For group 3 named Cylinder trying to read 160 patch face indices. For group 4 named Top trying to read 160 patch face indices. For group 5 named inlet trying to read 80 patch face indices. For group 6 named bottom trying to read 160 patch face indices. For group 7 named outlet trying to read 80 patch face indices. Sorting boundary faces according to group (patch) 0: right is faceZone 1: left is faceZone 2: Cylinder is faceZone 3: Top is patch 4: inlet is patch 5: bottom is patch 6: outlet is patch Constructing mesh with non-default patches of size: Top 160 inlet 80 bottom 160 outlet 80 --> FOAM Warning : From function polyMesh:olyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 626 Found 29680 undefined faces in mesh; adding to default patch. Adding cell and face zones Face Zone Cylinder 160 ideasUnvToFoam: ideasUnvToFoam.C:1271: int main(int, char**): Assertion `noveau > -1' failed. Aborted (core dumped) " |
Flow past a 2D cylinder - High Re (1E+05) - Cd too high | Pervispasco | OpenFOAM Running, Solving & CFD | 4 | March 14, 2022 03:19 |
Drag force coefficient too low for a flow past cylinder at Re= 1e05 | Scabbard | STAR-CCM+ | 2 | June 5, 2020 15:44 |
Flow past a cylinder at Re 1e05 using LES, drag force coefficient is to low | Scabbard | Main CFD Forum | 21 | June 19, 2018 14:58 |
Drag force coefficient too high for a flow past a cylinder using komega sst | Scabbard | OpenFOAM Running, Solving & CFD | 37 | March 21, 2016 17:16 |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 14:00 |
