September 23, 2014, 22:18 |
BlockMesh error.
Haijun Hu
Rep Power: 12 |
I want to creat two connected cylinders by wedge. The wall definition is always wrong. the code is as below. Who could help me ? wall (8 2 10 4) error.
it is the concentric circle face. /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.0 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) (0.3 0 0) (0 -3.490481e-4 1.999695e-2) (0.3 -3.490481e-4 1.999695e-2) (0.3 3.490481e-4 1.999695e-2) (0 3.490481e-4 1.999695e-2) (-0.01 0 0) (-0.01 -1.745241e-4 9.998477e-3) (0 -1.745241e-4 9.998477e-3) (-0.01 1.745241e-4 9.998477e-3) (0 1.745241e-4 9.998477e-3) ); blocks ( hex (0 1 1 0 2 3 4 5) (200 1 100) simpleGrading (50 1 0.05) hex (6 0 0 6 7 8 10 9) (50 1 25) simpleGrading (1 1 1) ); edges ( arc 2 5 (0 0 0) arc 3 4 (0.3 0 0) arc 8 10 (0 0 0) arc 7 9 (-0.01 0 0) ); patches ( patch inlet ( //(0 2 5 0) (6 7 9 6) ) patch outlet ( (1 3 4 1) ) wedge axi_symm-f ( (0 1 3 2) (6 0 8 7) ) wedge axi_symm-r ( (0 1 4 5) (6 0 10 9) ) wall wall ( //(2 3 4 5) (8 2 10 4) //(7 8 10 9) //default ) ); mergePatchPairs ( ); |
September 24, 2014, 08:22 |
ArathoN
Rep Power: 16 |
for better understanding you have to post the complete error, oaste the terminal output here so we can know what it is in particular. By teh way probably you forgot a wall or there are two blocks connected with inconsistent faces (different size or meshes).
September 24, 2014, 10:27 |
Haijun Hu
Rep Power: 12 |
Thank ArathoN.
The message is : Reading patches section Creating block mesh topology Reading physicalType from existing boundary file Default patch type set to empty --> FOAM FATAL ERROR: face 1 in patch 4 does not have neighbour cell face: 4(8 2 10 4) From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 127. FOAM aborting Segmentation fault: 11 ==================== |
September 25, 2014, 15:04 |
ArathoN
Rep Power: 16 |
sorry i can answer you only on the weekend, by the way control if you set up all the faces and that are properly connected and if you can post an image with teh geometry you considered this would ease me into discovering teh root of the error.
concentric circles mesh |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 10:17 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 10:30 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
