[Other] Dynamic Mesh: Morph internal mesh nodes
Old   September 15, 2014, 12:04
Default Dynamic Mesh: Morph internal mesh nodes
nucat is on a distinguished road
Hello foamers,
I have just a simple question: Is it possible to setup a dynamic mesh case in OF, where the nodes on boundary patches are fixed, but some internal nodes of the mesh are displaced?
I need a yPlus adaption. With other words the boundary cells have to become thinner in normal direction. I programmed a python script, where i calculate for a set of internal nodes the displace vector. Now I want to use this result to morph the mesh with standart OF tools?
If it is not possible, how to setup a case, where you can move nodes on a boundary with prescribed displace vectors for every node?
Thanks for help,
Nucat
nucat is offline   Reply With Quote
internal, morphing, node
[ICEM] Nuclear fuel assembly, Mesh Check: "missing internal faces, uncovered faces" swparth ANSYS Meshing & Geometry 2 June 27, 2017 08:12
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
