[Salome] Salome geometry viewing issue
Old   September 8, 2014, 00:35
Default Salome geometry viewing issue
Sean McBane
Kendrian is on a distinguished road
I don't know if this is a known issue, or user error, but I couldn't find it addressed already anywhere.
Having played around enough with OpenFOAM to want to do something more complicated than blockMesh permits, I downloaded and installed Salome. After some struggle, it seems to be working. However, when attempting to create geometry, the only entities that appear in the viewer are points. I've created lines, curves, faces, wires, extrusions, etc... and played around with view options and everything I can think of, but only points appear. What is the issue?
Thanks in advance to anyone who can offer assistance.
--Sean
Kendrian is offline   Reply With Quote
Old   October 20, 2014, 18:21
cutter is on a distinguished road
just an idea: Are you using Salome within a virtual machine?!
I've been observing similar problems while using Salome (and other OpenGL software) in a VirtualBox machine. If that's the case, try to change the video card settings of the VM or run Salome on a real box.
Cutter
cutter is offline   Reply With Quote
salome
[Salome] Trivial tips to generate geometry with Salome for CHT case student666 OpenFOAM Meshing & Mesh Conversion 0 October 5, 2017 01:08
mapFields issue with slight change in geometry alexflage OpenFOAM Running, Solving & CFD 3 November 29, 2015 18:18
Prism Layers issue for Model replicating Abaqus Co-Sim Mechanical Coupling Tutorial MTabone STAR-CCM+ 4 April 14, 2015 03:28
[Salome] how to create geometry with salome to make "IdeasUnvToFoam" working! amorenelchino OpenFOAM Meshing & Mesh Conversion 5 June 24, 2013 11:35
Gorlov-vawt geometry issue Jorg Main CFD Forum 0 July 24, 2012 17:20
