[snappyHexMesh] extrudeMesh + snappyHexMesh 2d wedge mesh |
September 7, 2014, 08:42 |
Tobias Holzmann
Rep Power: 52 |
Hi all,
i am trying to mesh a simple axis symmetric geometry. For that I mesh a nonsymetric geometry (shown in pictures). Then I want to extrude the front with extrudeMesh to generate a 2d rotation symmetrc mesh. This is working property but checkMesh give me a lot of errors. Do anybody has a suggestion why this occure? My steps: 1. generate backgroundmesh 2. snappyHexMesh (castellated + snap) 3. extrudeMesh - I tryed flattenMesh befor extrude mesh but that is not working. Here the output of checkMesh Code:
Mesh stats points: 36991 internal points: 0 faces: 72242 internal faces: 35524 cells: 17919 faces per cell: 6.0140633 boundary patches: 7 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 17614 prisms: 32 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 273 Breakdown of polyhedra by number of faces: faces number of cells 7 262 8 11 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology top 244 490 ok (non-closed singly connected) side 58 118 ok (non-closed singly connected) front 17919 18506 ok (non-closed singly connected) back 17919 18506 ok (non-closed singly connected) groundAndWall 492 985 ok (non-closed singly connected) inlet 6 13 ok (non-closed singly connected) nozzel 80 162 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 -0.005 -0.0022343265) (0.11988579 0.02 0.0082343265) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 1) Wedge front with angle 2.4999999 degrees Wedge back with angle 2.4999999 degrees All edges aligned with or perpendicular to non-empty directions. Boundary openness (-1.5889318e-15 3.1319549e-16 -6.6387106e-15) OK. Max cell openness = 2.7260862e-16 OK. Max aspect ratio = 2.0340928 OK. Minimum face area = 2.7234933e-09. Maximum face area = 5.2528493e-06. Face area magnitudes OK. ***Zero or negative cell volume detected. Minimum negative volume: -2.6273155e-09, Number of negative volume cells: 17919 <<Writing 17919 zero volume cells to set zeroVolumeCells Mesh non-orthogonality Max: 180 average: 177.62971 ***Number of non-orthogonality errors: 35524. <<Writing 35524 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 107766 faces are incorrectly oriented. <<Writing 72242 faces with incorrect orientation to set wrongOrientedFaces Max skewness = 0.4904183 OK. Coupled point location match (average 0) OK. Failed 3 mesh checks. End Code:
At local face at (0.10928851 -0.0043930049 0.0077716393) the normal (0.043619418 -2.2166221e-07 -0.99904822) differs from the average normal (0.043619386 -4.2341179e-10 -0.99904822) by 4.9963981e-14 Either correct the patch or split it into planar parts --> FOAM Warning : From function wedgePolyPatch::calcGeometry(PstreamBuffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72 Wedge patch 'back' is not planar. At local face at (0.10929251 -0.0041364963 0.007771814) the normal (0.043618896 -4.4251257e-07 -0.99904824) differs from the average normal (0.043619386 -4.2341179e-10 -0.99904822) by 4.3602494e-13 Either correct the patch or split it into planar parts --> FOAM Warning : From function wedgePolyPatch::calcGeometry(PstreamBuffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72 Wedge patch 'back' is not planar. At local face at (0.11900384 -0.0044040385 0.00819582) the normal (0.043619617 4.8947379e-07 -0.99904821) differs from the average normal (0.043619386 -4.2341179e-10 -0.99904822) by 2.9339209e-13 Either correct the patch or split it into planar parts --> FOAM Warning : From function wedgePolyPatch::calcGeometry(PstreamBuffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72 Wedge patch 'back' is not planar. At local face at (0.11925451 -0.0044021974 0.0082067643) the normal (0.043619548 1.9122314e-07 -0.99904821) differs from the average normal (0.043619386 -4.2341179e-10 -0.99904822) by 6.2926615e-14 Either correct the patch or split it into planar parts --> FOAM Warning : From function wedgePolyPatch::calcGeometry(PstreamBuffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72 Wedge patch 'back' is not planar. At local face at (0.11925456 -0.0041549939 0.0082067666) the normal (0.043619468 -2.038851e-07 -0.99904822) differs from the average normal (0.043619386 -4.2341179e-10 -0.99904822) by 4.8028036e-14 Either correct the patch or split it into planar parts --> FOAM Warning : From function wedgePolyPatch::calcGeometry(PstreamBuffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72 Wedge patch 'back' is not planar. At local face at (0.11950626 -0.0043992163 0.008217756) the normal (0.043619139 7.7844624e-08 -0.99904823) differs from the average normal (0.043619386 -4.2341179e-10 -0.99904822) by 6.7515101e-14 Either correct the patch or split it into planar parts --> FOAM Warning : From function wedgePolyPatch::calcGeometry(PstreamBuffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72 Wedge patch 'back' is not planar. At local face at (0.11975968 -0.0043975095 0.0082288204) the normal (0.043619288 7.067434e-08 -0.99904823) differs from the average normal (0.043619386 -4.2341179e-10 -0.99904822) by 1.4659395e-14 Either correct the patch or split it into planar parts --> FOAM Warning : From function wedgePolyPatch::calcGeometry(PstreamBuffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72 Wedge patch 'back' is not planar. At local face at (0.11975944 -0.0041506596 0.0082288101) the normal (0.043619244 -2.5265662e-08 -0.99904823) differs from the average normal (0.043619386 -4.2341179e-10 -0.99904822) by 2.0892414e-14 Either correct the patch or split it into planar parts Any hints are kindly appreciated Regards Tobi
Keep foaming, Tobias Holzmann |
September 7, 2014, 08:48 |
Tobias Holzmann
Rep Power: 52 |
Okay I managed a lot of things by changing the patches of extrusion from front to back. Now checkMesh is okay:
Mesh stats points: 36991 internal points: 0 faces: 72242 internal faces: 35524 cells: 17919 faces per cell: 6.0140633 boundary patches: 8 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 17614 prisms: 32 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 273 Breakdown of polyhedra by number of faces: faces number of cells 7 262 8 11 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology axis 0 0 ok (empty) top 244 490 ok (non-closed singly connected) side 58 118 ok (non-closed singly connected) front 17919 18506 ok (non-closed singly connected) back 17919 18506 ok (non-closed singly connected) groundAndWall 492 985 ok (non-closed singly connected) inlet 6 13 ok (non-closed singly connected) nozzel 80 162 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 -0.005 -0.0052343265) (0.11988579 0.02 0.0052343265) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 1) Wedge front with angle 2.5 degrees Wedge back with angle 2.5 degrees All edges aligned with or perpendicular to non-empty directions. Boundary openness (6.9999917e-16 -1.0560211e-15 -1.0271528e-14) OK. Max cell openness = 3.2088808e-16 OK. Max aspect ratio = 2.0340939 OK. Minimum face area = 2.7234931e-09. Maximum face area = 5.2528493e-06. Face area magnitudes OK. Min volume = 6.1406691e-13. Max volume = 2.6273154e-09. Total volume = 1.5537909e-05. Cell volumes OK. Mesh non-orthogonality Max: 19.65403 average: 2.3702856 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.49041924 OK. Coupled point location match (average 0) OK. Mesh OK. End
September 7, 2014, 08:56 |
Tobias Holzmann
Rep Power: 52 |
Problem solved by changing writeFormat from ascii to binary.
http://www.cfd-online.com/Forums/ope...tml#post302438
October 29, 2015, 15:29 |
2 D axis symmetric
Antony Premkumar
Rep Power: 11 |
Hi Tobi,
Thanks for the post. I am facing a similar problem. When i extrude mesh from patch as 'sector' it runs fine but checkMesh gives 2 errors. but when i extrude as 'wedge', extrudeMesh is crashing. Thanks & Regards, Antony Ashley Raja |
November 9, 2015, 08:30 |
Antony Premkumar
Rep Power: 11 |
Thank you very much !! The tutorial hydraulicJumpStream helped alot.
I have now solved the problem. |
February 29, 2016, 21:31 |
#7 | |
Nila
Rep Power: 12 |
I have followed your hydraulic jump stream tutorial and was able to create a wedge geometry. But I am getting exactly same warnings as you posted. It is saying the front and back wedge face is not planner. The checkMesh is giving me 3 errors. I have changed my write precision from ascii to binary but no improvement was achieved. I saw that at some places the mesh is not smooth may be which is making the wedge non planner. I am attaching my case here. Also I am attaching image showing non-smooth mesh. Please have a look at my case.Till now your suggestions helped me a lot to move forward. Help me one more time Please. Thanks Zannatul |
March 1, 2016, 04:43 |
Tobias Holzmann
Rep Power: 52 |
I would like to ask you, if I can put your case as a demonstrating tutorial on my homepage? Some hints to you case:
My result is at least: Code:
Checking geometry... Overall domain bounding box (5.381473299e-19 0 -0.006647594717) (0.1522549509 0.1400000006 0.006647594717) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 1) Wedge front with angle 2.499999999 degrees Wedge back with angle 2.499999999 degrees All edges aligned with or perpendicular to non-empty directions. Boundary openness (-1.57321546e-14 4.635052846e-19 1.398782485e-14) OK. Max cell openness = 3.237941764e-16 OK. Max aspect ratio = 2.360620704 OK. Minimum face area = 1.61861228e-08. Maximum face area = 1.452864706e-05. Face area magnitudes OK. Min volume = 1.11902422e-11. Max volume = 1.127843696e-08. Total volume = 0.0001021924827. Cell volumes OK. Mesh non-orthogonality Max: 18.4156806 average: 0.4810143038 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.5287255358 OK. Coupled point location match (average 0) OK. Mesh OK. End Cheers,
March 2, 2016, 11:30 |
#9 |
Tobias Holzmann
Rep Power: 52 |
The case I made for your geometry is available on my homepage: http://holzmann-cfd.de/index.php/en/openfoam
Please tell me if I am not allowed to share it.
March 2, 2016, 13:42 |
#10 | |
Nila
Rep Power: 12 |
Sorry for replying late. I am glad that you consider my case to be shareable in your homepage. You can do so. And thank you so much for looking in my case and your help to solve it. I am going to look over it. And I will follow the hints you have mentioned. One thing I need to ask you is that what do you think can be a better way for my background mesh? Thank you again. Zannatul |
March 2, 2016, 15:04 |
#11 |
Tobias Holzmann
Rep Power: 52 |
To you question: it is up to you ... The background mesh should be pure quadric. This is best for sHM.
Tobi
March 2, 2016, 16:02 |
#12 |
Nila
Rep Power: 12 |
March 4, 2016, 01:51 |
#13 | |
Nila
Rep Power: 12 |
Hi Tobi What I want now is finer mesh close to walls and coarse mesh inside. So I used Feature refinement level as 3. After extruding the mesh, nfaces of axis should be zero. But I am getting some value. So after I do create patch it is again saying wedge is not planar. My feature refinement is not good that is why I guess this error is occurring. I have seen that when you solved my case you got good feature edge refinement. What is the trick here? I checked the tutorial you told me about it. I saw you used .obj file for feature refinement. In my case should I similarly use .obj file of the outline of my geometry? I have never used blender. Can solidworks do that? Please let me know a solution for this problem. I have attached my case and two images for your understanding. Thanks! Zannatul |
March 4, 2016, 15:04 |
#15 | |
Nila
Rep Power: 12 |
Zannatul |
March 7, 2016, 09:32 |
#16 |
Tobias Holzmann
Rep Power: 52 |
You can use surfaceRefinement (because you will extrude at least and it does not matter in your case) or use featureEdge refinement and check out my tutorial on my homepage about featureEdge refinement.
Keep in mind that a surface refinement will lead to better curvature. If this will influence at last the 2d extrusion - i don't know.
March 8, 2016, 18:32 |
#17 | |
Nila
Rep Power: 12 |
Thanks for the suggestion. If you do not mind can I ask you one thing? The case of mine you demonstrated in your page, in that case you have used 0 level surface refinement and 0 level feature refinement. But still the mesh along the curve was good and the wedge shape was perfect. Can you please briefly explain me this? Was it possible because the cells of the background mesh was very fine? Zannatul |
March 13, 2016, 19:31 |
#18 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: I took a brief look into the page and what's written on this current thread and:
If you use surface refinement, this means that snappyHexMesh might have certain regions that are more uniform than others, due to how the refinement transitions between levels and near the curves. If you can provide detailed images with and without refinement, I can point out the reasons why this is happening. |
March 13, 2016, 19:41 |
#19 |
Tobias Holzmann
Rep Power: 52 |
Thanks Bruno for the details. I want to add some more information. Using surfaceFeatureRefinement you have to be sure that sHM realize the feature edges. Some times it happens, that the feature edges have to be modified (position change). I demonstrated this in the "surfaceFeatureEdge" tutorial on my homepage.
In your case I would prefer the surfaceRefinement to get a smooth refinement at each of the wall faces. Also (as Bruno mentioned) I suggest you to use a uniform background mesh.
March 18, 2016, 21:34 |
#20 |
Nila
Rep Power: 12 |
Hi Bruno and Tobi
Extremely sorry for responding late. This is our spring break week and I am away from my work station. I will not be able to go through your suggestions and post my queries before next week. I will post next week. Thank you both for increasing my knowledge. Zannatul |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 18:16 |
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh | czhongrong | OpenFOAM Meshing & Mesh Conversion | 1 | January 20, 2016 06:26 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 07:42 |
Fluid-Structure-Interaction on wedge mesh | WiWo | OpenFOAM | 6 | March 6, 2010 08:18 |
