[snappyHexMesh] extrudeMesh + snappyHexMesh 2d wedge mesh |
November 15, 2018, 11:42 |
#41 | |
Tony
Rep Power: 10 |
I'll be trying the swap and update this post if it worked out for me. |
December 7, 2018, 13:40 |
#42 |
Tony
Rep Power: 10 |
Unfortunately, a simple swap from between back and front faces did not work.
I had noticed for my particular mesh, that one of the cells had edges which extended into the negative x domain (before extrusion) If I edited those points to not step past the wedge axis, the new mesh extrusion had no errors. Although it passes checkMesh with no errors, unfortunately, the code halts before reaching the first timestep (ex. right when it hits the runtime loop). I am currently trying another way to make my base 2D planar mesh to see if I can get the extrudeMesh utility to function better. Apologies on the slow response; since the runtime error I became occupied by another project. |
January 15, 2019, 19:04 |
#43 |
Tony
Rep Power: 10 |
Delayed posting: The solver issue was found.
The solver did not like printing out the U along the new axis of symmetry. (Suggest: either skip this runtime plot or move it slightly off-axis) |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 18:16 |
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh | czhongrong | OpenFOAM Meshing & Mesh Conversion | 1 | January 20, 2016 06:26 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 07:42 |
Fluid-Structure-Interaction on wedge mesh | WiWo | OpenFOAM | 6 | March 6, 2010 08:18 |
