[snappyHexMesh] Problems with coarse/unsnapped cells in snappyHexMesh
Old   July 29, 2014, 08:10
Cool Problems with coarse/unsnapped cells in snappyHexMesh
Alexander Coles
scareneb is on a distinguished road
Hi fellow SHM users, this is my first post on the forums so apologies for any lack in clarity in the description/set-up.
I have been trying to mesh a fairly simple wing geometry where a wing section alters from a standard NACA0012 to the same aerofoil with a 25 degree plain flap (see picture 1).
The wing is enclosed at both ends by the blockMesh which was causing problems with SHM but that seemed to have sorted itself when I increased the max cell parameters in SHM Dict. All good there...
Now, however, I am still having problems with very large cells forming on the faces which are normal to the aerofoil chord (see pictures 2&3), and also SHM has problems snapping at cells which are at the leading edges of both wing sections. I have tried adding refinement zones at two locations (the wing/flap split section and the leading edge of the flap).
Below is my SHM Dict file. I delete most of the commenting in the Dict's to make it a bit easier to modify, sorry if this makes things confusing.
Any help/tips on this issue would be greatly appreciated (I'm still new to OF)! Also, I have changed a lot of the "angle" parameters from 0 to 30 to 60 to 180 etc and this doesn't seem to solve the issue.. Total cell count is ~700,000.
// Which of the steps to run
castellatedMesh true;
snap true;
addLayers false;
geometry
EulerWing25.stl
type triSurfaceMesh;
name wing;
refinementBoxA
type searchableBox;
min (0.65 0.96 -0.15);
max (1.02 1.04 0.05);
refinementBoxB
type searchableBox;
min (0.96 0 -0.125);
max (1.02 0.99 -0.1);
// Initial mesh generation
castellatedMeshControls
// Refinement parameters
maxLocalCells 350000;
maxGlobalCells 450000;
minRefinementCells 10;
maxLoadUnbalance 0.10;
nCellsBetweenLevels 4;
features
refinementSurfaces
wing
level (8 9);
patchInfo
type wall;
resolveFeatureAngle 60;
refinementRegions
wing
mode distance;
levels ((0.01 5) (0.05 3));
refinementBoxA
mode inside;
levels ((1 12));
refinementBoxB
mode inside;
levels ((1 12));
locationInMesh (-1 0.6 1);
allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
nSmoothPatch 10;
tolerance 4;
nSolveIter 50;
nRelaxIter 10;
nFeatureSnapIter 15;
implicitFeatureSnap false;
explicitFeatureSnap true;
multiRegionFeatureSnap false;
// Settings for the layer addition.
addLayersControls
relativeSizes false;
layers
wing
nSurfaceLayers 10;
expansionRatio 1.1;
finalLayerThickness 0.2;
minThickness 0.0005;
nGrow 1;
featureAngle 60;
nRelaxIter 3;
nSmoothSurfaceNormals 1;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5;
maxThicknessToMedialRatio 0.3;
minMedianAxisAngle 130;
nBufferCellsNoExtrude 0;
nLayerIter 50;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
maxNonOrtho 65;
maxBoundarySkewness 20;
maxInternalSkewness 20;
maxConcave 80;
minVol 1e-13;
minArea -1;
minTetQuality 1e30;
minTwist 0.02;
minDeterminant 0.001;
minFaceWeight 0.02;
minVolRatio 0.01;
minTriangleTwist -1;
errorReduction 0.75;
nSmoothScale 4;
relaxed
maxNonOrtho 75;
debug 0;
mergeTolerance 1E-6;
File Type: jpg Screenshot from 2014-07-29 12:00:06.jpg (16.3 KB, 52 views)
File Type: jpg Screenshot from 2014-07-29 11:42:43.jpg (98.0 KB, 57 views)
File Type: jpg Screenshot from 2014-07-29 11:59:30.jpg (34.5 KB, 57 views)
scareneb is offline   Reply With Quote
Old   July 29, 2014, 11:26
Icaro A. Accordi
icaroaccordi is on a distinguished road
My guess is that you are using shorten cells in span-wise direction. Probably you had decreased the size of the domain without changing the cell count in that direction. If you want a sharp corner you can use feature edges in the snapHexMeshDict after using the command surfaceFeatureExtract (you need a dictionary to do that). However is going to be a hell to get nice boundary layers in sharp corners. I hope that I would help you.
icaroaccordi is offline   Reply With Quote
Old   August 13, 2014, 08:13
Alexander Coles
Thanks for your suggestions Icaro! They did help, however, I have read that newer versions of OF do not require the surfaceFeatureExtractDict and the feature is now built in with the resolveFeatureAngle. I tried this with 90 degrees and the cells snapped perfectly!
Also, I was going a bit OTT on the refinement of surfaces and regions, and therefore the number of cells SHM could reach (defined by the maxGlobal/maxLocal cell parameters) was quickly used up & no additional cells were not added!
I have attached my new SHMDict and a few new images!
This SHMDict also works well with my smooth transition wing, of which I am looking to compare aerodynamic performance with! (3rd pic)
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
snap true;
addLayers false;
geometry
NACA0012.stl
name wing;
flap_22deg_25c.stl
name flap;
refinementBoxA
type searchableBox;
min (0.74 2.35 -0.12);
max (2.00 2.45 0.06);
// refinementBoxB
// type searchableBox;
// min (0.96 0 -0.125);
// max (1.02 0.99 -0.1);
maxLocalCells 500000;
maxGlobalCells 1200000;
minRefinementCells 1;
features
refinementSurfaces
wing
level (3 4);
patchInfo
type wall;
flap
level (3 4);
patchInfo
type wall;
resolveFeatureAngle 90;
refinementRegions
wing
mode distance;
levels ((0.1 4) (0.5 3));
flap
mode distance;
refinementBoxA
mode inside;
levels ((1 7));
// refinementBoxB
// mode inside;
// levels ((1 12));
locationInMesh (-1.01 0.62 1);
snapControls
nSmoothPatch 10;
tolerance 4;
nSolveIter 60;
nRelaxIter 10;
implicitFeatureSnap true;
explicitFeatureSnap false;
addLayersControls
layers
wing
nSurfaceLayers 10;
flap
nSurfaceLayers 10;
expansionRatio 1.1;
nGrow 0;
featureAngle 60;
nRelaxIter 3;
nSmoothSurfaceNormals 3;
nSmoothNormals 3;
minMedianAxisAngle 60;
nLayerIter 50;
// where to undo.
meshQualityControls
maxNonOrtho 65;
maxBoundarySkewness 4;
maxInternalSkewness 4;
maxConcave 60;
minVol 1e-13;
minArea 1e-13;
minTetQuality 1e30;
minTwist 0.02;
minFaceWeight 0.02;
minVolRatio 0.01;
nSmoothScale 4;
relaxed
maxNonOrtho 75;
minVol 1e-13;
debug 0;
dict, openfoam, problem, shm, snappyhexmesh
[snappyHexMesh] snappyHexMesh can't create refimenet region clktp OpenFOAM Meshing & Mesh Conversion 3 February 27, 2022 10:26
[snappyHexMesh] snappyHexMesh <-> dynamicMeshDict problem with protected cells Billy_16 OpenFOAM Meshing & Mesh Conversion 2 November 21, 2020 04:34
[snappyHexMesh] Problems meshing an impeller with snappyHexMesh kandelabr OpenFOAM Meshing & Mesh Conversion 13 June 9, 2017 07:18
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
