[Other] Map runtime the field from an internal patch to a boundary patch |
July 18, 2014, 05:19 |
Dear users,
I ' m quite new to OF and I have to deal with this problem: I have a cyclic pipe that I merged with a divergent nozzle like in the figure below. After merging I have for the patch in section B two names, one derived from the nozzle and the other one from the pipe. I would like to map runtime the field in section B (internal patch) to section A. I tried to use cyclic boundary conditions for the pipe but it doesn't work beacuse I think that I can't impose a boundary condition on an internal patch. So I tried in another way: changing the boundary file and putting sectionA { type mappedPatch; nFaces 8; startFace 45368; sampleMode nearestPatchFace; sampleRegion region0; samplePatch sectionB; offsetMode uniform; offset ( 0 0 0.096 ); } but it doesn't work. Any idea of how I can fix my problem? Thank you very much! |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 04:21 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
[mesh manipulation] Using createPatch in place of couplePatches | sripplinger | OpenFOAM Meshing & Mesh Conversion | 8 | November 13, 2009 08:14 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
