[blockMesh] Strange error depending on the coordinates of vertices(not the order)
Old   July 15, 2014, 01:35
Question Strange error depending on the coordinates of vertices(not the order)
Kerem Aydemir
aydemirk is on a distinguished road
Hi everyone,
I was working on my blockMeshDict file. For my thesis I have to build a mesh for a micro-ramp. First I tried to build the structure without the boundaries with easy coordinates like these :
vertices
(0 0 -4.98) //0
(4 0 0) //1
(4 1.7 0) //2
(0 0 4.98) //3
blocks
hex (0 1 2 2 3 3 3 3) (20 20 20) simpleGrading (1 1 1)
and everything works fine I get no error but when I change only the coordinates of the vertices and nothing else to the coordinates I need, I get this error:
'face 380 in patch 0 does not have neighbour cell face: 4(8175 8607 8608 8196)'
Only thing I am doing is changing the vertices like these(only x component basically);
vertices
(330.83 0 -4.98) //0
(342.01 0 0) //1
(342.01 1.7 0) //2
(330.83 0 4.98) //3
I have no idea what causes the problem. It is only x component that changes and shouldn't be a problem. What do you think is the problem?
Thank you
aydemirk is offline   Reply With Quote
Old   August 21, 2014, 03:44
jokerito is on a distinguished road
I think the problem is with the number of cells in each direction to your specific size of the tetraeder. If there are two lines in one direction, it could be, that they "hit" the edge (one to the left, one to the right) in such a bad case, that there is another face between them. It is a little bit hard to explain, but if you think a little bit about it, it should be clear.
So you should decrease the number of cells in each direction:
     hex (0 1 2 2 3 3 3 3) (12 4 10) simpleGrading (1 1 1)
Kind regards
jokerito is offline   Reply With Quote
coordinates, face error, points, vertices
[Scripting]: How to get the coordinates of a 2D airfoil @ different angles of attack? CfdIntro Main CFD Forum 2 December 12, 2017 11:23
How grid resolution for a wave number depends on the scheme order? marinkobezu Main CFD Forum 9 September 21, 2017 13:11
1st order vs 2nd order ken FLUENT 8 March 14, 2013 04:43
CFL condition for higher order schemes Shyam Main CFD Forum 2 February 14, 2008 15:24
1st order temporal & 2nd order spatial Prateep Chatterjee FLUENT 0 January 19, 2003 01:31
