[Commercial meshers] Converting an abaqus mesh using matlab scripts and fluentMeshToFoam
Old   June 30, 2014, 08:12
Default Converting an abaqus mesh using matlab scripts and fluentMeshToFoam
Michael D.
MichaelD is on a distinguished road
Hi everyone,
I'm currently trying to import a mesh created in abaqus into OpenFOAM, by using matlab scripts and the abaqus .inp file to create a fluent .msh file. From there I was planning to use fluentMeshToFoam.
However, using fluentMeshToFoam gives the following error:
[michael@semar-linnex3 meshtest3]$ fluentMeshToFoam output.msh
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.3.0
Exec : fluentMeshToFoam output.msh
Date : Jun 30 2014
Time : 11:16:58
Host : "semar-linnex3.se-as.no"
PID : 935
Case : /home/michael/OpenFOAM/michael-2.3.0/run/meshtest3
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Reading header: "abaqusToAnsys_cylinder.m"
Dimension of grid: 3
Number of cells: 9092
number of faces: 36626
Number of points: 18698
Reading points
Other readCellGroupData: 2 1 2384 1 4
Reading uniform cells
Reading uniform faces
FINISHED LEXING
dimension of grid: 3
Creating shapes for 3-D cells
--> FOAM FATAL ERROR:
face 0 does not belong to cell 2717. Face owner: -1 neighbour: 2700
From function create3DCellShape(const label cellIndex, const labelList& faceLabels, const labelListList& faces, const labelList& owner, const labelList& neighbour, const label fluentCellModelID)
in file create3DCellShape.C at line 122.
FOAM aborting
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
in "/opt/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/fluentMeshToFoam"
#4 __libc_start_main in "/lib64/libc.so.6"
Aborted (core dumped)
What exactly does this error mean? It's apparent that something's wrong with the .msh file, and I've tried looking for something indicating 0 is designated as having element 2717 as owner, but couldn't find anything. The output.msh file is in the link below:
https://drive.google.com/file/d/0ByI...it?usp=sharing
Any help is appreciated!
MichaelD is offline   Reply With Quote
Old   July 2, 2014, 07:34
Michael D.
Turns out there were a couple of boundary faces (in a different part of the mesh) that were misidentified as internal faces, and when that was fixed, the mesh loads just fine.
I'm still not sure why this error message appeared; it seems unrelated to what fixed the mesh. Oh well, it works now at least!
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
