[Commercial meshers] Mesh conversion from fluent to OpenFOAM
Old   June 20, 2014, 08:51
Exclamation Mesh conversion from fluent to OpenFOAM
harshawardhank
harsha_kulkarni is on a distinguished road
I want to convert fluent mesh to OpenFOAM. I used command fluent3DMeshToFoam fluent.msh. After that boundary file created in Polymesh directory. it contain names of boundary in geometry. After that what need to do. Need to change blockeshDict and files in 0 folder ??
thanks and regards
Harshawardhan
harsha_kulkarni is offline   Reply With Quote
Old   June 28, 2014, 18:26
Joachim Herb
jherb is on a distinguished road
The https://github.com/OpenFOAM/OpenFOAM.../icoFoam/elbow tutorial includes the conversion of a fluent mesh. Look at the Allrun file what has to be done to set up and run a case.
jherb is offline   Reply With Quote
[Commercial meshers] Fluent mesh to OF conversion theHumbleOne OpenFOAM Meshing & Mesh Conversion 7 July 30, 2021 09:44
[Commercial meshers] SolidWorks to ANSYS to OpenFoam mesh conversion failed nuclear_swapnil OpenFOAM Meshing & Mesh Conversion 1 October 11, 2017 01:38
[Commercial meshers] Problem encountered in converting Fluent mesh to OpenFOAM Mesh sathya123 OpenFOAM Meshing & Mesh Conversion 2 November 22, 2015 04:22
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[Commercial meshers] Fluent Mesh to OpenFoam: Internal Surface has to be a wall sebastian OpenFOAM Meshing & Mesh Conversion 6 October 21, 2010 05:36
