hassan
Rep Power: 12 ![]() |
Hello everyone, I am really stuck with this problem for couple of days now
![]() ![]() ![]() https://www.dropbox.com/sh/3wd70o7w9...xJm8I0IoGhSdXa Regards and thanks for you help ![]() |
hassan
UPDATE: I have recreated the geometry step by step and exported the corresponding mesh. It turns out that the problem lies with the patches creation and export. What I did as explained in one of the tutorials is that I created the geometry and then used explode to get the faces that constitute the inlet and outlet patches. Afterwards, these faces were grouped under patches. Then these patches in the geometry were used to create the group patches in the mesh which then exported along in the mesh file. Is this the right way to construct and export the patches or there is another way that works?? your help guys is really appreciated thanks
#3 | |
Geir Karlsen
Rep Power: 13 ![]() |
![]() http://www.caelinux.org/wiki/index.p...ELinux_2007.29 |
Wouter van der Meer
Rep Power: 18 ![]() |
Ahadi,
I also am not an expert. My strategy is to use the geom module to create STL files of my patches and with HELYX-OS I create with snappyHexMesh my mesh. I export the polyMesh directory to my case and change the boundaries, because HELYX-OS does not have my solvers, otherwise you can HELYX-OS to run your case. But I noticed in your mesh that there is no internal mesh and openFOAM needs that. So the same as gkarlsen said. Hope this helps Wouter |
#5 | |
Geir Karlsen
![]() My answer above is only relevant if you actually want to use Salome meshing for your geometry. Geir |
Rep Power: 14 ![]() |
FYI I am also struggeling with snappy hex mesh on multi region and just started a new thread. http://www.cfd-online.com/Forums/ope...ns-salome.html regards dirk |
[Salome] how to setFields in openFOAM when you have imported mesh from salome or other package | 13msmemusman | OpenFOAM Meshing & Mesh Conversion | 11 | May 18, 2022 07:30 |
[Salome] mesh conversion Salome --> OpenFoam | vaina74 | OpenFOAM Meshing & Mesh Conversion | 42 | March 4, 2022 20:41 |
[Salome] Converting Salome wedge mesh to OpenFOAM | anon_q | OpenFOAM Meshing & Mesh Conversion | 4 | March 13, 2019 15:13 |
[Salome] Step to export mesh from SALOME to OpenFoam for 3D MRF geometry | aminem | OpenFOAM Meshing & Mesh Conversion | 0 | September 16, 2014 10:18 |
Converting Salome hybrid mesh to OpenFOAM | Arnoldinho | OpenFOAM | 4 | March 28, 2012 10:24 |
