June 13, 2014, 10:28 |
Mesh Conversion to Openfoam problem
hassan
Rep Power: 12 |
Hello everybody, sorry that my first thread is a problem! I was trying to convert a simple geometry (T-shape pipe, two inlet and one outlet) mesh from Salome 7.3.0 to openfoam 2.3.0 on Ubuntu 14.04 and I ran into this error. This is my first time using both softwares so I am suspecting installation issues. I have been looking in Google using different keywards relating to the error but no luck. One more info could be relevant is that I am running this on mac 64 bit processor. I used ideasunvtofoam command and it gave me this message:
Create time Processing tag:164 Starting reading units at line 3. l:1 units:" SI: Meter (newton)" unitType:2 Unit factors: Length scale : 1 Force scale : 1 Temperature scale : 1 Temperature offset : 273.15 Processing tag:2420 Skipping tag 2420 on line 9 Skipping section at line 9. Processing tag:2411 Starting reading points at line 20. Read 5642 points. Processing tag:2412 Starting reading cells at line 11307. First occurrence of element type 11 for cell 1 at line 11308 First occurrence of element type 44 for cell 766 at line 13603 First occurrence of element type 41 for cell 2326 at line 16723 Read 0 cells and 5655 boundary faces. Processing tag:2467 Starting reading patches at line 24915. For group 6 named inlet trying to read 1125 patch face indices. For group 7 named inlet trying to read 1125 patch face indices. For group 8 named outlet trying to read 1125 patch face indices. For group 9 named wall trying to read 2280 patch face indices. Sorting boundary faces according to group (patch) 0: inlet is #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 at ??:? #4 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #5 at ??:? Segmentation fault (core dumped) My question is just where do you think the poblem lies exactly. When I ran tutorials of Openfoam I did not encounter any problem. Yet when I tried to convert the mesh from Salome I get this. Thank you in Advance Last edited by Ahadi; June 13, 2014 at 11:51. |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 08:31 |
[Commercial meshers] SolidWorks to ANSYS to OpenFoam mesh conversion failed | nuclear_swapnil | OpenFOAM Meshing & Mesh Conversion | 1 | October 11, 2017 01:38 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
[Commercial meshers] mesh conversion from ansys mesher to openfoam | Dusan1224 | OpenFOAM Meshing & Mesh Conversion | 2 | November 5, 2015 04:41 |
Moving mesh problem OpenFoam 141 | kassiotis | OpenFOAM Running, Solving & CFD | 30 | April 15, 2015 00:10 |
