[Other] Keep certain area undeceomposed using scotch
Old   May 29, 2014, 08:34
Question Keep certain area undeceomposed using scotch
HenrikSmutje is on a distinguished road
Hello everybody,
I'm currently using the decompose method scotch for my cases which works really great so far. The problem I came across now is, that another algorithm I use does not work if the area it is acting in is decomposed. One solution would of course be to use simple decomposition but I reckon performance will go down quite a lot if I do so ( have not tested yet).
I use OpenFOAM 2.1.x and it uses scotch 5.1.11 . I tried to find an option in the manual for scotch that would allow the definition of a certain area that has to be kept in one processor domain but was not successful so far.
Does anyone have a solution for that, honestly the scotch manual is quite confusing for me. Actually I do not even need to make sure that a whole volume but rather just a straight line of defined length, start and end point is kept in one domain.
Thanks
Henrik
HenrikSmutje is offline   Reply With Quote
decomposepar, openfoam 2.1.x, processor boundary, scotch
Non overlap area fractions saisanthoshm88 CFX 13 December 11, 2024 17:03
Problem with reference area alfaben STAR-CCM+ 3 April 21, 2020 10:46
problem "face 0 area does not match neighbour by xxx%" in parallel run Aleigus OpenFOAM 0 July 2, 2017 13:10
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
