[Other] Plasma actuator induced flow simulation
Old   May 28, 2014, 10:52
Post Plasma actuator induced flow simulation
Mominul MuKuT
mukut is on a distinguished road
I am trying to simulate plasma induced flow based on suzen model . I already simulated the flow using PHOENICS by CHAM UK. The flow domain is as follows:
Now I am trying to simulate this using openfoam. I have posted regarding this few months ago in this forum and suggested to use multi regionFOAM for such solid-air domain. Then I have modified the multi region heater tutorical case as follows:
Here dielectric material is Kapton and electrodes are cupper. How can I define the material?
In my previous simulation using Phoenics, it found that both side plasma induced identical flow structure so now I think it should be reduced to as follows:
Is it possible to make such geometry consist of solid-air domain by simple blockmesh? Or using muti region by toposet is okey?
I have tried to make above flow domain by blockMESH but don't understand how to define the face of colored region. Here brown color represent electrodes and faded red color indicates dielectric material. I have chosen the left face of block1,4,7,13 are inlet, right face of block 3,6,9,12, 15 are outlet. top and bottom are as top and bottom wall respectively. and front & back are as usual empty. But how can I define color region?
Thanks in advance.
mukut is offline   Reply With Quote
Old   May 29, 2014, 12:19
Mominul MuKuT
Any suggestion??
Old   May 31, 2014, 02:44
Mominul MuKuT
anybody help me please......
geometry, mesh, openfoam, plasma actuator, suzen model
parametric study in flow simulation topaz FloEFD, FloWorks & FloTHERM 1 July 13, 2015 09:50
how to get a time-accurate solution in Flow Simulation drdet FloEFD, FloWorks & FloTHERM 4 January 20, 2015 08:11
Differences and functions of Solidworks Simulation and Solidworks Flow Simulation? alpharays Main CFD Forum 0 April 19, 2012 04:13
Simulation of flow induced by plasma actuator mukut Phoenics 0 April 21, 2010 08:32
