[Other] dynamicTopoFVMesh and pointDisplacement
Old   May 27, 2014, 11:17
Default dynamicTopoFVMesh and pointDisplacement
Ke Yam
RandomUser is on a distinguished road
Hi all,
I am using OpenFoam 2.2.x with dynamicTopoFVMesh and Mesquite 2.3.0 to simulate a valve rotated by flow in a domain. The problem is simple 2D with a uniform coming from one side and exiting the other side. I am using pimpleDyFoam.
I found that the solver works well when fixedValuePatches is used but does not work if it is changed to usePointDisplacement.
This is the error that the solver gives:
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigSegv::sigHandler(int) at ??:?
#2 in "/usr/lib/libc.so.6"
#3 Foam::valuePointPatchField<Foam::Vector<double> >::evaluate(Foam::UPstream::commsTypes) at ??:?
#4 Foam::GeometricField<Foam::Vector<double>, Foam:ointPatchField, Foam:ointMesh>::GeometricBoundaryField::evaluate () at ??:?
#5 Foam::mesquiteMotionSolver::applyFixedValuePatches () at ??:?
#6 Foam::mesquiteMotionSolver::solve() at ??:?
#7 Foam::motionSolver::newPoints() at ??:?
#8 Foam::dynamicTopoFvMesh::update() at ??:?
at ??:?
#10 __libc_start_main in "/usr/lib/libc.so.6"
#11
at ??:?
zsh: segmentation fault (core dumped) pimpleDyMFoam.
Any idea how I can make this work?
Here's the link to my setup:
https://www.dropbox.com/s/sepmqcsjda...eValvM3.tar.gz
Regards,
Ke
RandomUser is offline   Reply With Quote
Old   May 29, 2014, 12:44
Sandeep Menon
deepsterblue will become famous soon enough
Ke,
Out of curiosity, does this happen after a topology change? In that case, it looks like the pointPatchFields are not being mapped correctly. You may want to print out the size of the pointPatchFields and point patchSizes before / after the topology change to see if they are consistent.
Sandeep
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   May 30, 2014, 14:19
Ke Yam
Hi Sandeep
Thank you for replying to my thread.
Yes, I think it occurs after a topology change. Here's the output:
Create time
Create mesh for time = 0
Selecting dynamicFvMesh dynamicTopoFvMesh
Selecting motion solver: mesquiteMotionSolver
Reading field p
Reading field U
void fvMesh::makeSf() : assembling face areas
polyMesh::globalData() const : Constructing parallelData from processor topology
This needs the patch faces to be correctly matched
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model laminar
void fvMesh::V() : slicing cellVolumes
void fvMesh::makeC() : assembling cell centres
void fvMesh::makeCf() : assembling face centres
Reading field rAU if present
No finite volume options present
PIMPLE: no residual control data found. Calculations will employ 2 corrector loops
Starting time loop
forces forces:
--> FOAM Warning :
    From function polyBoundaryMesh::patchSet(const wordReList&, const bool, const bool) const
    in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 777
    Cannot find any patch or group names matching wing
Courant Number mean: 0.0002622653374 max: 0.01999999524
deltaT = 0.001
Time = 0.001
Solving for point motion:  Initial residual: 1 Final residual: 0.009509871676 No Iterations: 28
Solving for point motion:  Initial residual: 1 Final residual: 0.008395577821 No Iterations: 35
Found normal from empty patch 5 twoDPointCorrector normal: (0 0 1)
 ~~~ Mesh Quality Statistics ~~~
 Min: 0.5777995078
 Max: 0.9626499351
 Mean: 0.7714097498
 Cells: 3368
Face: 3372 needs to be flipped.
 Cell[0]: 1698: 5(3371 3372 8574 8575 3367)
 Cell[1]: 2597: 5(4445 4446 10372 10373 3372)
 Common Faces: Set 1: 8574: 3(1390 496 1388), 10372: 3(496 490 1388)
 Common Faces: Set 2: 8575: 3(3200 3198 2306), 10373: 3(2306 3198 2300)
 Old face: 4(1388 496 2306 3198)
 Old faceEdges: 4(244 1136 4066 9244)
New flipped face: 4(1390 490 2300 3200)
New boundary face[0]: 8574: 3(1390 496 490)
New boundary face[1]: 10372: 3(490 1388 1390)
New boundary face[2]: 8575: 3(2300 2306 3200)
New boundary face[3]: 10373: 3(3200 3198 2300)
..................[ cut out to save space]
Face: 2 needs to be flipped.
 Cell[0]: 0: 5(0 1 2 5178 5179)
 Cell[1]: 2366: 5(4153 4154 9910 9911 2)
 Common Faces: Set 1: 5178: 3(1809 1206 806), 9910: 3(1206 691 806)
 Common Faces: Set 2: 5179: 3(3619 2616 3016), 9911: 3(3016 2616 2501)
 Old face: 4(806 1206 3016 2616)
 Old faceEdges: 4(554 954 5146 10324)
New flipped face: 4(1809 691 2501 3619)
New boundary face[0]: 5178: 3(1809 1206 691)
New boundary face[1]: 9910: 3(691 806 1809)
New boundary face[2]: 5179: 3(2501 3016 3619)
New boundary face[3]: 9911: 3(3619 2616 2501)
Edge Swapping complete.
 Topo modifier time: 0.053183 s
 Bisections :: Total: 0, Surface: 0
 Collapses  :: Total: 0, Surface: 0
 Swaps      :: Total: 828, Surface: 0
void fvMesh::makeMagSf() : assembling mag face areas
Registered gradients:
4
U
rAU
nu
p
 Mapping time: 0.556732 s
 Mesh reOrdering
 Mesh Info [n]:
 Edges: 12166
 Faces: 11914
 Cells: 3368
 Internal Edges: 1558
 Internal Faces: 4926
 nPatches: 6
 Patch Starts [Face]: 6(4926 5010 5052 5094 5136 5178)
 Patch Sizes  [Face]: 6(84 42 42 42 42 6736)
 Patch Starts [Edge]: 6(1558 1642 1683 1724 1767 1810)
 Patch Sizes  [Edge]: 6(84 41 41 43 43 10356)
 Mesh Info [n+1]:
 Edges: 12166
 Faces: 11914
 Cells: 3368
 nPatches: 6
 Patch Sizes: [Face]: 6(84 42 42 42 42 6736)
 Patch Sizes: [Edge]: 6(84 41 41 43 43 10356)
Checking index ranges...Done.
Checking face-cell connectivity...Done.
Checking for unused points...Done.
Checking edge-face connectivity...Done.
Checking cell-point connectivity...Done.
ReOrdering points...Done.
ReOrdering cells...Done.
ReOrdering faces...Done.
ReOrdering edges...Done.
 Reordering time: 0.027282 s
void polyMesh::clearAddressing() : clearing topology
void polyMesh::setInstance(const fileName& inst) : Resetting file instance to "0.001"
void polyMesh::initMesh() : initialising primitiveMesh
void polyMesh::updateMesh(const mapPolyMesh&) : updating addressing and (optional) pointMesh/pointFields
fvMesh::storeOldVol(const scalarField&) : Storing old time volumes since from time 0 and time now 1 V:3368
fvMesh::storeOldVol() : Stored old time volumes V0:3368
void dynamicTopoFvMesh::mapFields(const mapPolyMesh&): Mapping fv fields.
Conservatively mapping volScalarField nu
 Field: nu Mapping patch: GEOM size: 84 sizeBeforeMapping: 84
 Field: nu Mapping patch: OUTLET size: 42 sizeBeforeMapping: 42
 Field: nu Mapping patch: INLET size: 42 sizeBeforeMapping: 42
 Field: nu Mapping patch: TOPWALL size: 42 sizeBeforeMapping: 42
 Field: nu Mapping patch: BOTTOMWALL size: 42 sizeBeforeMapping: 42
 Field: nu Mapping patch: frontAndBackPlanes size: 0 sizeBeforeMapping: 0
Conservatively mapping volScalarField rAU
 Field: rAU Mapping patch: GEOM size: 84 sizeBeforeMapping: 84
 Field: rAU Mapping patch: OUTLET size: 42 sizeBeforeMapping: 42
 Field: rAU Mapping patch: INLET size: 42 sizeBeforeMapping: 42
 Field: rAU Mapping patch: TOPWALL size: 42 sizeBeforeMapping: 42
 Field: rAU Mapping patch: BOTTOMWALL size: 42 sizeBeforeMapping: 42
 Field: rAU Mapping patch: frontAndBackPlanes size: 0 sizeBeforeMapping: 0
Conservatively mapping volScalarField p
 Field: p Mapping patch: GEOM size: 84 sizeBeforeMapping: 84
 Field: p Mapping patch: OUTLET size: 42 sizeBeforeMapping: 42
 Field: p Mapping patch: INLET size: 42 sizeBeforeMapping: 42
 Field: p Mapping patch: TOPWALL size: 42 sizeBeforeMapping: 42
 Field: p Mapping patch: BOTTOMWALL size: 42 sizeBeforeMapping: 42
 Field: p Mapping patch: frontAndBackPlanes size: 0 sizeBeforeMapping: 0
Conservatively mapping volVectorField U
 Field: U Mapping patch: GEOM size: 84 sizeBeforeMapping: 84
 Field: U Mapping patch: OUTLET size: 42 sizeBeforeMapping: 42
 Field: U Mapping patch: INLET size: 42 sizeBeforeMapping: 42
 Field: U Mapping patch: TOPWALL size: 42 sizeBeforeMapping: 42
 Field: U Mapping patch: BOTTOMWALL size: 42 sizeBeforeMapping: 42
 Field: U Mapping patch: frontAndBackPlanes size: 0 sizeBeforeMapping: 0
Mapping volTensorField grad(U)
Conservatively mapping surfaceScalarField phi
 Field: phi Mapping patch: GEOM size: 84 sizeBeforeMapping: 84
 Field: phi Mapping patch: OUTLET size: 42 sizeBeforeMapping: 42
 Field: phi Mapping patch: INLET size: 42 sizeBeforeMapping: 42
 Field: phi Mapping patch: TOPWALL size: 42 sizeBeforeMapping: 42
 Field: phi Mapping patch: BOTTOMWALL size: 42 sizeBeforeMapping: 42
 Field: phi Mapping patch: frontAndBackPlanes size: 0 sizeBeforeMapping: 0
tmp<scalarField> polyMesh::movePoints(const pointField&) :  Moving points for time 0.001 index 1
bool polyMesh::checkMeshMotion(const pointField&, const bool, const bool) const: checking mesh motion
    Min volume = 5.727559221e-05. Max volume = 0.0001041416386.  Total volume = 0.215692028.  Cell volumes OK.
    Minimum face area = 0.001012498991. Maximum face area = 0.004000000952.  Face area magnitudes OK.
    Face pyramids OK.
bool polyMesh::checkFaceOrthogonality(const bool, labelHashSet*) const: checking mesh non-orthogonality
    Mesh non-orthogonality Max: 28.39302579 average: 20.81131324
    Non-orthogonality check OK.
Mesh motion check OK.
 ~~~ No flux correction ~~~
    Min volume = 4.862774937e-05. Max volume = 9.912823019e-05.  Total volume = 0.215692028.  Cell volumes OK.
    Minimum face area = 0.0008596252833. Maximum face area = 0.004178322181.  Face area magnitudes OK.
    Face pyramids OK.
    Mesh non-orthogonality Max: 27.06962956 average: 20.63451199
 Min: 0.7313930133
 Max: 0.9626499351
 Mean: 0.774391345
 Cells: 3368
GAMG:  Solving for pcorr, Initial residual = 1, Final residual = 0.013209383, No Iterations 14
time step continuity errors : sum local = 6.928726577e-06, global = -1.701657221e-06, cumulative = -1.701657221e-06
PIMPLE: iteration 1
DILUPBiCG:  Solving for Ux, Initial residual = 0.1752459437, Final residual = 0.0006955123468, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 0.003396926098, No Iterations 1
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.006144049203, No Iterations 16
time step continuity errors : sum local = 3.539652493e-06, global = -6.932935213e-07, cumulative = -2.394950742e-06
PIMPLE: iteration 2
DILUPBiCG:  Solving for Ux, Initial residual = 0.4288754813, Final residual = 9.623027865e-07, No Iterations 3
DILUPBiCG:  Solving for Uy, Initial residual = 0.2458947718, Final residual = 3.479113767e-07, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.06048700728, Final residual = 9.02062096e-08, No Iterations 26
time step continuity errors : sum local = 1.124818144e-08, global = -2.147428623e-09, cumulative = -2.397098171e-06
ExecutionTime = 0.85 s  ClockTime = 1 s
End
void polyMesh::clearGeom() : clearing geometric data
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#3  Foam::GeometricField<Foam::Vector<double>, Foam::pointPatchField, Foam::pointMesh>::GeometricBoundaryField::writeEntry(Foam::word const&, Foam::Ostream&) const at ??:?
#4  Foam::GeometricField<Foam::Vector<double>, Foam::pointPatchField, Foam::pointMesh>::writeData(Foam::Ostream&) const at ??:?
#5  Foam::regIOobject::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const at ??:?
#6  Foam::objectRegistry::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const at ??:?
#7  Foam::objectRegistry::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const at ??:?
#8  Foam::Time::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const at ??:?
 at ??:?
#11
 at ??:?
zsh: segmentation fault (core dumped)  pimpleDyMFoam > log
I compared the mesh that has been changed and the original mesh. I found that the number of points, faces and cells are preserved. They are the same but the details have been changed. Indeed, I viewed all the boundaries of the mesh on paraview and they are changed (and the change is the same with the one computed with fixedValuePatch). However, I can view all boundaries except the internalMesh. Attempting to view internalMesh causes paraview to crash. The crash error:
--> FOAM FATAL ERROR:
edgeFaces_ full at entry:36 for edge 3 0
    From function calcEdgeAddressing(const faceList&, const label)
    in file meshes/meshShapes/cellMatcher/cellMatcher.C at line 181.
FOAM aborting
#1  Foam::error::abort() at ??:?
#2  Foam::cellMatcher::calcEdgeAddressing(int) at ??:?
#3  Foam::prismMatcher::matchShape(bool, Foam::List<Foam::face> const&, Foam::List<int> const&, int, Foam::List<int> const&) at ??:?
#4  Foam::degenerateMatcher::match(Foam::List<Foam::face> const&, Foam::List<int> const&, int, Foam::List<int> const&) at ??:?
#5  Foam::degenerateMatcher::match(Foam::primitiveMesh const&, int) at ??:?
#6  Foam::primitiveMesh::calcCellShapes() const at ??:?
#7  Foam::primitiveMesh::cellShapes() const at ??:?
#8  Foam::vtkPV3Foam::volumeVTKMesh(Foam::fvMesh const&, Foam::vtkPV3Foam::polyDecomp&) at ??:?
#9  Foam::vtkPV3Foam::convertMeshVolume(vtkMultiBlockDataSet*, int&) at ??:?
#10  Foam::vtkPV3Foam::Update(vtkMultiBlockDataSet*, vtkMultiBlockDataSet*) at ??:?
#11  vtkPV3FoamReader::RequestData(vtkInformation*, vtkInformationVector**, vtkInformationVector*) at ??:?
#12  vtkExecutive::CallAlgorithm(vtkInformation*, int, vtkInformationVector**, vtkInformationVector*) in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#13  vtkDemandDrivenPipeline::ExecuteData(vtkInformation*, vtkInformationVector**, vtkInformationVector*) in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#14  vtkCompositeDataPipeline::ExecuteData(vtkInformation*, vtkInformationVector**, vtkInformationVector*) in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#15  vtkDemandDrivenPipeline::ProcessRequest(vtkInformation*, vtkInformationVector**, vtkInformationVector*) in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#16  vtkStreamingDemandDrivenPipeline::ProcessRequest(vtkInformation*, vtkInformationVector**, vtkInformationVector*) in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#17   in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#18  vtkDemandDrivenPipeline::ProcessRequest(vtkInformation*, vtkInformationVector**, vtkInformationVector*) in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#19  vtkStreamingDemandDrivenPipeline::ProcessRequest(vtkInformation*, vtkInformationVector**, vtkInformationVector*) in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#20   in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#21  vtkDemandDrivenPipeline::ProcessRequest(vtkInformation*, vtkInformationVector**, vtkInformationVector*) in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#22  vtkStreamingDemandDrivenPipeline::ProcessRequest(vtkInformation*, vtkInformationVector**, vtkInformationVector*) in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#23   in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#24  vtkDemandDrivenPipeline::ProcessRequest(vtkInformation*, vtkInformationVector**, vtkInformationVector*) in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#25  vtkStreamingDemandDrivenPipeline::ProcessRequest(vtkInformation*, vtkInformationVector**, vtkInformationVector*) in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#26   in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#27  vtkDemandDrivenPipeline::ProcessRequest(vtkInformation*, vtkInformationVector**, vtkInformationVector*) in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#28  vtkStreamingDemandDrivenPipeline::ProcessRequest(vtkInformation*, vtkInformationVector**, vtkInformationVector*) in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#29  vtkDemandDrivenPipeline::UpdateData(int) in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#30  vtkStreamingDemandDrivenPipeline::Update(int) in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#31  vtkPVDataRepresentation::ProcessViewRequest(vtkInformationRequestKey*, vtkInformation*, vtkInformation*) at ??:?
#32  vtkPVView::CallProcessViewRequest(vtkInformationRequestKey*, vtkInformation*, vtkInformationVector*) at ??:?
#33  vtkPVView::Update() at ??:?
#34  vtkPVRenderView::Update() at vtkPVRenderView.cxx:?
#35  vtkPVRenderViewCommand(vtkClientServerInterpreter*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&) at ??:?
#36  vtkClientServerInterpreter::ProcessCommandInvoke(vtkClientServerStream const&, int) at ??:?
#37  vtkClientServerInterpreter::ProcessOneMessage(vtkClientServerStream const&, int) at ??:?
#38  vtkClientServerInterpreter::ProcessStream(vtkClientServerStream const&) at ??:?
#39  vtkPVSessionCore::ExecuteStreamInternal(vtkClientServerStream const&, bool) at ??:?
#40  vtkPVSessionCore::ExecuteStream(unsigned int, vtkClientServerStream const&, bool) at ??:?
#41  vtkPVSessionBase::ExecuteStream(unsigned int, vtkClientServerStream const&, bool) at vtkPVSessionBase.cxx:?
#42  vtkSMProxy::ExecuteStream(vtkClientServerStream const&, bool, unsigned int) at ??:?
#43  vtkSMViewProxy::Update() at ??:?
#44  vtkSMViewProxy::StillRender() at ??:?
#45  vtkSMAnimationScene::TickInternal(double, double, double) at ??:?
#46  vtkAnimationCue::Tick(double, double, double) in "/home/p004208/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkCommon.so.pv3.12"
#47  vtkPVAnimationSceneCommand(vtkClientServerInterpreter*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&) at ??:?
#48  vtkSMAnimationSceneCommand(vtkClientServerInterpreter*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&) at ??:?
#49  vtkClientServerInterpreter::ProcessCommandInvoke(vtkClientServerStream const&, int) at ??:?
#50  vtkClientServerInterpreter::ProcessOneMessage(vtkClientServerStream const&, int) at ??:?
#51  vtkClientServerInterpreter::ProcessStream(vtkClientServerStream const&) at ??:?
#52  vtkSIProperty::ProcessMessage(vtkClientServerStream&) at ??:?
#53  vtkSIVectorPropertyTemplate<double, int>::Push(double*, int) at ??:?
#54  vtkSIVectorPropertyTemplate<double, int>::Push(paraview_protobuf::Message*, int) at
Looks like it has got to do with the edgefaces. I am not sure what to do from here so would like to ask for your advice again.
Thank you.
Regard,
Ke
Old   March 2, 2015, 17:03
maalan is on a distinguished road
Hi Sandeep!
Just a question: My case is an oscillating and pitching foil in current, and I think the most efficient way to run it is by moving a cell region and remeshing outdoors. Well, is possible with dynamicTopoFVMesh? What do you think is the best way to do it? (I discard laplacian displacement or RBF for not being efficient approaches)
Cheers,
Best!
maalan is offline   Reply With Quote
Old   March 2, 2015, 17:43
Sandeep Menon
I think this should be possible. If you create an airfoil with a fixed mesh around it (can be hexes, poly, etc), and then have a tri-prism / tetrahedral mesh surrounding it, you can then mark all points in the fixed mesh and put them in a separate pointZone. Once that is done, you can move this pointZone in a rigid-body sense along with your airfoil, and remesh in the tri / tet regions as necessary.
Sandeep Menon
Old   March 2, 2015, 18:19
Thank you for your fast reply, Sandeep! I will try and let you know when possible. BTW, what do you about the solidBodyMotionFvMesh alternative? do you find it faster than the previous one?
Thanks again!
Best.
Old   April 26, 2018, 08:30
sepehr_s is on a distinguished road
Hi Maalan
can you perform fixed region around airfoil?
sepehr_s is offline   Reply With Quote
Questions on dynamicTopoFvMesh danvica OpenFOAM Running, Solving & CFD 80 April 16, 2019 17:58
