[blockMesh] How can I define functions with m4?
Old   April 21, 2014, 11:07
Default How can I define functions with m4?
Olivia Nalen
entropie is on a distinguished road
Dear OF-Users,
I'm trying to create a blockMeshDict with m4. I need to define all coordinates on the Z-axis as functions of coordinates on the X-axis. So far my m4-code looks like this:
define (x1, 7)
define (x2, 5)
define (x20, 4)
define (z1, calc(x1*2+1))
define (z2, calc(x2*2+1))
define (z20, calc(x20*2+1))
etc.
And the problem is, I have about 100 coordinates and it is a bit awkward to define all 100 coordinates one by one.
Maybe can somebody tell me how can I just once define a function for all Z-coordinates, if it's possible?
Best regards,
Olivia
entropie is offline   Reply With Quote
Old   August 13, 2014, 10:38
cutter is on a distinguished road
you could use any scripting or programming language to write the contents of the blockMeshDict.
For example the following Python script
#!/usr/bin/env python
def func(x):
    return x*2.+1.
def main():
    for i in range(0, 11):
        x = .1*i
        z = func(x)
        print 'x{} {};'.format(i,x)
        print 'z{} {};'.format(i,z)
if __name__ == "__main__":
    main()
would result in
x0 0.0;
z0 1.0;
x1 0.1;
z1 1.2;
x2 0.2;
z2 1.4;
x3 0.3;
z3 1.6;
x4 0.4;
z4 1.8;
x5 0.5;
z5 2.0;
x6 0.6;
z6 2.2;
x7 0.7;
z7 2.4;
x8 0.8;
z8 2.6;
x9 0.9;
z9 2.8;
x10 1.0;
z10 3.0;
Cutter
cutter is offline   Reply With Quote
Old   August 13, 2014, 11:00
The above post was just a workaround for your problem. Regarding your initial question on m4, maybe the following link helps:
http://www.slac.stanford.edu/comp/un...nfo/m4_11.html
functions, mesh
udf-Surface Reaction Rate-parse error in line 34 priya_1985 FLUENT 1 November 10, 2014 03:48
Wall functions ivan-s Main CFD Forum 0 August 25, 2014 13:35
udf explaination Ijaz Fluent UDF and Scheme Programming 4 May 8, 2012 05:24
UDF problem libia87 Fluent UDF and Scheme Programming 1 May 4, 2012 22:49
UDF carbon conversion papteo Fluent UDF and Scheme Programming 1 August 18, 2011 08:32
