[Other] How to view vertices numbers in paraFoam
Old   March 11, 2014, 12:41
Question How to view vertices numbers in paraFoam
Matthew
MPD78 is on a distinguished road
I know the vertices numbers can be shown in paraFoam. However, how can you use paraFoam to display the vertices numbers?
Thanks
Matt
MPD78 is offline   Reply With Quote
Old   March 20, 2014, 05:32
CFDUser
CFDUser_ is on a distinguished road
Im also looking for same. is there any way to see points in paraView?
paraFoam -block ll show vertices number but not its vertices
CFDUser_ is offline   Reply With Quote
Old   April 11, 2014, 09:38
Talking Solved
Matthew
CFDUser, I never saw your response. Thanks. I actually posted the wrong command.
Matt
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 19:25
[OpenFOAM.com] paraFoam cannot open due to Qt issues - [Solved/Information] u2berggeist OpenFOAM Installation 2 July 2, 2018 18:03
[ICEM] Specifying Periodic Vertices Causes Mesh Overlap Josh ANSYS Meshing & Geometry 10 July 8, 2010 03:39
[blockMesh] Problem using paraFoam to view cavityGrade mesh file felik9 OpenFOAM Meshing & Mesh Conversion 1 September 27, 2009 16:31
HELP!! Prandtl numbers in RNG k-e turbulence model maoasis FLUENT 0 April 24, 2006 11:51
