[snappyHexMesh] snappyHexMesh - snap to outermost surface
Old   March 5, 2014, 00:50
Default snappyHexMesh - snap to outermost surface
J. Brindley
oldirtybrindley is on a distinguished road
I have an stl, thats not the "cleanest" of all time, there are some surfaces that intersect and some that are inside the outersurface. I wiuld like snappyHexMesh to snap ti the outermost of these points. How can I do this?
oldirtybrindley is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh failing to snap ("did not find surface within...") Jaworski.Mike OpenFOAM Meshing & Mesh Conversion 7 December 2, 2019 21:13
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 06:53
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[snappyHexMesh] Problem with snappyhexMesh: modelling a pore chamber and pore throat model Saideep OpenFOAM Meshing & Mesh Conversion 5 May 10, 2015 15:46
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
