[Other] How bad is this mesh?
Old   March 4, 2014, 05:21
Question How bad is this mesh?
avinashjagdale
avinashjagdale is on a distinguished road
i have done unstructured mesh on a turbine blade cooling network using Salome.
After converting to polymesh.
I am attaching the checkMesh output.
Can you please give your comments on mesh quality.
avinashjagdale is offline   Reply With Quote
Old   March 5, 2014, 07:29
Hrvoje Jasak
It's fine - put a limiter on the laplacian and try 1 non-orthogonal corrector and you are good to go.
Hrv
Hrvoje Jasak
Old   March 5, 2014, 07:56
avinashjagdale
Thank you sir. I will put it for solving.
I am also generating mesh on same geometry using snappyhexmesh. Hoping for less non-orthogonality and skewness.
I will post checkmesh log of that too. It will be good exercise to compare both tools.
Old   March 11, 2014, 07:40
Smile Comparing snappyHexMesh and Salome
avinashjagdale
I am attaching checkMeshlog files for both the cases.
SnappyHexMesh has give much better quality mesh. As you can compare the Non-Orhtogonality Check and Skewness Check for both.
Comments are welcome.
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) shubham jain ANSYS Meshing & Geometry 1 April 10, 2017 06:03
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
