[snappyHexMesh] entries in refinement region were not used |
February 16, 2014, 07:57 |
Fabrizio
Rep Power: 12 |
hello everybody,
i'm meshing a simple cylinder connected to 2 conduct, the first in the upper and the other in the lower side of the body. i have some problems in the castelleted step. I can not refine the cylinder and the upper conduct with the "distance" principle in refinementRegions i tried to split the stl with surfaceSplit and give the stl file instead of the name of the region but snappy does not use the surface.. anyone have suggestion? Thank's fabrizio |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 02:37 |
[snappyHexMesh] snappyHexMesh can't create refimenet region | clktp | OpenFOAM Meshing & Mesh Conversion | 3 | February 27, 2022 10:26 |
[snappyHexMesh] Multi Region Mesh of a car filter | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 3 | September 11, 2019 20:34 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 18:16 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
