[Other] how to avoid AMI weighting 0
Old   January 16, 2014, 07:46
Default how to avoid AMI weighting 0
fedvasu is on a distinguished road
Hi foamers,
I am working on a rotating geometry simulation, moderate Re.
I get error after significant number of timesteps where AMI min has gone to 0, I understand that when there is mismatch between level of refinement of the body (A propeller/plate etc) and the rotating domain in which it is present leads to AMI go to 0.
but how do i calculate that thing a-prior i? is there a rule of thumb?
after setting up BC, making sure mesh is proper, it gets frustrating to know that AMI weighting goes to 0 at say iteration number 20000, is there a way to avoid it?
fedvasu is offline   Reply With Quote
ami, meshing, openfoam 2.2.x, rotating domain
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 22:51
mapField error rvl565 OpenFOAM Pre-Processing 1 September 6, 2018 17:13
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
