[blockMesh] Problems with "holes" or "gaps" in Baffle as internal wall of zero thickness
Old   January 11, 2014, 10:40
Default Problems with "holes" or "gaps" in Baffle as internal wall of zero thickness
RuKa
RuKa is on a distinguished road
I´m new here and not that advanced in OpenFoam.
I´m trying to make a simple zero thickness wall. But the created Baffle has depending on my mesh and size of cells some gaps in it where the flow can pass through.
Basically I´m running:
blockMesh
sopoSet
createBaffles -overwrite
and run the simulation as a DNS. Courant Number allways less than 0.8.
I would appreciate any help!
RuKa is offline   Reply With Quote
baffle, blockmesh
Divergence in AMG solver! marina FLUENT 20 August 1, 2020 12:30
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
BC for a permeable internal wall Andi-HH OpenFOAM Pre-Processing 6 April 24, 2012 11:39
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 06:44
[Salome] Salome Geometry question (Pipe with certain wall thickness) Hectux OpenFOAM Meshing & Mesh Conversion 1 April 8, 2009 07:44
