[Other] 'Cannot find patchField entry for outlet'
Old   November 24, 2013, 16:50
Wink 'Cannot find patchField entry for outlet'
cesarjets is on a distinguished road
I have a geometry that is essentially a cube with the left face as inlet and the right face as outlet.
I can generate the mesh with blockMesh but I'm trying to use simpleFoam solver
"Cannot find patchField entry for outlet".
This is what I have done. not sure if the cyclic patches would be necessary?
wondering how I could corect this?
Thanks much, any help on this will be appreciated
| \\ / O peration | Version: 2.2.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 0.1;
vertices
(0 0 0)
(8 0 0)
(8 4 0)
(0 4 0)
(0 0 1)
(8 0 1)
(8 4 1)
(0 4 1)
blocks
hex (0 1 2 3 4 5 6 7) (40 40 1) simpleGrading (1 1 1)
edges
boundary
inlet
type patch;
faces
(0 4 7 3)
outlet
type patch;
faces
(1 2 6 5)
left
type cyclic;
neighbourPatch right;
faces ((0 4 7 3));
right
type cyclic;
neighbourPatch left;
faces ((1 5 6 2));
fixedWalls
type wall;
faces
(0 1 5 4)
(0 3 2 1)
(3 7 6 2)
(4 5 6 7)
cesarjets is offline   Reply With Quote
Old   November 25, 2013, 01:29
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
in your blockMeshDict example you are missing a
after your outlet definition (after faces( ); in your outlet definition) and before your left patch definition.
chegdan is offline   Reply With Quote
Cannot find patchField entry for InletWall range_rover OpenFOAM Running, Solving & CFD 5 November 18, 2020 22:21
Parallel snappyHexMesh problem: Cannot find patchField entry for procBoundary2to7 hconel OpenFOAM Pre-Processing 0 October 5, 2018 18:22
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 07:32
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 07:30
